Saucepan drawer cage fixings
Verns63
Has thanked: 2 times
Post by Verns63 »
So these fixings are obviously broken and need replacing. They're from an old MFI kitchen saucepan drawer; they hold a metal cage to the base of the drawer. I'd like to source replacements so I can fix the drawer... does anyone out there have any idea what they might be called and/or where I might be able to get them from?
Has thanked: 833 times
Been thanked: 3636 times
Would a plastic cable grip clip do it?
Verns63 (Thu Nov 05, 2020 2:38 pm)
Dave54
Has thanked: 1300 times
Been thanked: 1175 times
Post by Dave54 »
Several plastic washers stacked together?
ayjay
Has thanked: 458 times
Been thanked: 1708 times
Post by ayjay »
Are they the base fittings for Pan Drawer Rails? (they look familiar, without me venturing out to the garage to check)
pan drawer rails.jpg (48.44 KiB) Viewed 3192 times
Bob225
Has thanked: 106 times
Been thanked: 882 times
Post by Bob225 »
Is it a pull out rack and the door mounts to the front ?
eg. https://www.rejsltd.co.uk/product/pull- ... ant-multi/
Only thing that springs to mind is metal p-clips
Bob225
Post by Bob225 »
What size are the basket rods ? Something like a closed terry clip may work
Better idea - Cable tie eyelet and a cable tie
EG. https://www.ebay.co.uk/itm/Cable-Tie-Ey ... SwPEFbpjcs
Verns63
Post by Verns63 »
They're for fixing a "cage" to the base of the drawer, ayjay... I think I'm going to try some cable ties with some cable tie bases instead of the fixings to see if they work. Frustratingly I just can't find the actual item anywhere...
Appreciate your reply. :-)
Verns63
Post by Verns63 »
Bob225 wrote: Thu Nov 05, 2020 7:23 pm Is it a pull out rack and the door mounts to the front ?
Yes, Bob225. The drawer front goes onto the open end of this photo... I'm going to try some cable ties and cable tie bases... thanks for your reply.
Verns63 (Fri Nov 06, 2020 11:51 am)
Return to “Kitchen Fitting”
