Single light switch mysteriously swapped round
My beloved is convinced that the single lightswitch in the bedroom has suddenly started working the opposite way. There are no other switches operating this light (guaranteed).
Although I have used the switch daily for 25 years I can’t be sure.
Is this possible or does one of us need to go and see a doctor?
- Has thanked: 47 times
- Been thanked: 2590 times
How do you suppose it has changed if there is only ONE Light switch controlling the light.
Have you had any "contractors" in recently?
- kellys_eye
- Has thanked: 357 times
- Been thanked: 1790 times
????Scaffoldking wrote: ↑Tue Nov 10, 2020 10:27 pm Although I have used the switch daily for 25 years I can’t be sure.
Is there (or was there) ever another entrance to that room? Is there a switch in a wall/recessed cupboard? Got (mischievous) kids/grandkids? All factors to be wary of!
- Has thanked: 105 times
- Been thanked: 878 times
Push the bottom for ON and the top for OFF
Unless someone has turned the switch upside down
This covid lockdown can make the mind behave strangely - some young children have regressed due to the lack of Stimulation and social interaction, forgetting how to use a knife and fork etc.
- camallison
- Has thanked: 127 times
- Been thanked: 108 times
I have an even stranger phenomenon - someone keeps moving switches to the other side of entrances to rooms. They're never where they were last time I was searching in the dark.
Colin
Colin
- Has thanked: 1300 times
- Been thanked: 1175 times
When you say "guaranteed" no other switches, did you wire it up in the first place, or trace the wiring recently?
Bedrooms often have two way switching with a pull switch pull switch, not necessarily over where the is bed now. Anything in the back of a fitted wardrobe, down the back of furniture or anything like that where it's got inadvertently switched?
- ericmark
- Has thanked: 118 times
- Been thanked: 783 times
I would agree with @Dave54 seems likely a two way switch you have not found, how many wires connect to switch, 2 or 3?
Power off.................
Pop the switch off the wall, 2 wires its 1 way, 3 or 4 it has 2 way switching (excluding earth)
