LED Light fitting question.
adewolves
Has thanked: 1 time
Post by adewolves »
I know very little about electrics so would welcome some help with fitting a LED ceiling light. I have attached the image of the fitting. The cable from the ceiling has 2 wires, blue and brown but as you can see the wires from the LED driver are both brown. I would have thought that they would be brown and blue and joined together with the corresponding colours from the ceiling cable in the block that I have circled. Any advice would be most welcome.
ericmark
Has thanked: 118 times
Been thanked: 783 times
Post by ericmark »
With the supply to that driver it does not matter which live wire goes where, neutral and line can be can be swapped in that unit.
The reason for having line and neutral not reverse is the fuse is only put in the line, so where no fuse or single pole switch involved then they can be swapped both line and neutral are considered as live.
These users thanked the author ericmark for the post:
adewolves (Sat Jan 30, 2021 1:25 pm)
adewolves
Has thanked: 1 time
Post by adewolves »
Like in the image atached?
ericmark
Post by ericmark »
Yes but also an earth wire of course.
kellys_eye
Has thanked: 357 times
Been thanked: 1790 times
Post by kellys_eye »
Double insulated - no earth required.
OnlyMe
Approved Electrician
Has thanked: 225 times
Been thanked: 662 times
Post by OnlyMe »
kellys_eye wrote: Sat Jan 30, 2021 3:55 pm Double insulated - no earth required.
The driver is double insulated but the fitting most definitely is not.
ericmark
Post by ericmark »
Image means earth, can't see any class II item having that sign.
Return to “Lighting”
