Hello,
I'm going to install a light fitting in my cupboard but there is no lighting circuit in there, however there is socket which is on it's own 16A circuit with nothing else on that circuit. So would it be acceptable to spur off from the back of that socket into a fused spur with a 3A fuse in it to supply the light fitting or would I have to somehow tap into the main lighting circuit?
Just so you know I am able to complete the wiring safely and correctly.
Sandy.
Supply for a light fitting.
- Has thanked: 1 time
- Approved Electrician
- Has thanked: 225 times
- Been thanked: 662 times
Yes - provided the circuit is RCD protected. Domestic properties now require lights to be RCD protected.
- These users thanked the author OnlyMe for the post:
- sandyfleming87 (Sun Feb 21, 2021 4:57 pm)
Thanks OnlyMe for the advice, yes the circuit is RCD protected.
Sandy.
Sandy.
