- It is currently Tue Feb 25, 2025 12:32 pm
Replacement for AU-60T dimmable transformer with dual input
Hi, I m helping my mum replace the transformers in her kitchen as many have gone and she can't see well. I thought it would be straightforward as I ve done it before in mine, however she has dual input transformers aurora AU-60T that have 2 lives, 2 neutrals and 2 earths going into them. I ve attached a pic.
I ve searched the Internet for a replacement and they appear to be discontinued and I am struggling to find something else that csn cater for dual input.
I really want to avoid her having to pay someone to rewire if possible.
Please help!
Thank you!
Please help!
Thank you!
- 20210220_102515.jpg (174.91 KiB) Viewed 1801 times
Sarah m
- arco_iris
- Has thanked: 184 times
- Been thanked: 535 times
The doubled-up wires are whats called a loop, simply join the two wires together in a chocblock then from that use a short single wire into the transformer. Any 60 watt dimmable transformer will work (as long as the lights are not LED, in which case you would need a constant current led driver).
Don't turn the light switch on while you're doing this.
arco_iris
- arco_iris
I have four that I no longer need, I've messaged you.
- 20210223_082356.jpg (191.77 KiB) Viewed 1789 times
arco_iris
- moderator2
- UHM Super Moderator
- Has thanked: 155 times
- Been thanked: 570 times
Post by moderator2 »
arco_iris, New members can't send / receive PM's until they have made 10 posts.
moderator2
- arco_iris
I know, told her that & gave her another option.
arco_iris
- arco_iris
Oh, missed the word "receive". You can contact her though?
arco_iris
- moderator2
Not possible without breaking GDP Regs.
moderator2
- ericmark
- Has thanked: 118 times
- Been thanked: 785 times
As said it is simply to allow transformers to be daisy chained, the other option is a junction box, there are today electronic transformers which go from zero to 60 watt, so they can power LED lamps. But LED lamps can cause problems as you can get AC only and DC only versions, and some of the AC only it has to be 50 Hz so a toroidal transformer not an electronic transformer is required. Most are AC/DC but I have found some marked 50 Hz.
A driver is a DC current regulated supply, but the lighting industry has made a habit of poor naming, so also get DC voltage regulated power supplies called drivers by manufacturers, they seem to name a new item after the item it replaced, so an electronic transformer replaced the toroidal transformer which was all well and good until LED came out and they would not work on existing electronic transformer but worked OK on the old toroidal transformers which last for decades so still common.
ericmark
- Approved Electrician
- Has thanked: 225 times
- Been thanked: 664 times
The chocblock also needs to be in a chocbox.arco_iris wrote: ↑Tue Feb 23, 2021 7:00 am![]()
Or use these (or similar)
https://www.tlc-direct.co.uk/Products/GKLC20.html
OnlyMe
