Prebuilt large units up the stairs?
tadaska
Has thanked: 227 times
Been thanked: 11 times
Post by tadaska »
What are your experiences regarding getting a prebuilt 1.2m long unit up the stairs in a usual council estate block? Is it doable?
This is going to be the largest of the ones I buy: https://www.diy-kitchens.com/showunit.a ... FMLIVX7Qkk
Has thanked: 831 times
Been thanked: 3630 times
If you think about it how do sofas get in using the same route? I cannot think that no flats in the block have them because of access.
OnlineOnline
tadaska
Post by tadaska »
dewaltdisney wrote: Thu Mar 18, 2021 8:58 am If you think about it how do sofas get in using the same route? I cannot think that no flats in the block have them because of access.
I don't know, I bought a sofa that came in 4 pieces and was assembled. My kitchen worktops (3 meter long) had to be lifted onto the balcony using ropes so I am a bit worried about pre-assembled units. I take it then that they do fit?
The flats would have been designed with access for bulky items to get in, I would have thought a 1.2m length would be okay. You have the fallback of using a rope to haul it up if the (much heavier) worktops came in that way.
tadaska (Thu Mar 18, 2021 9:50 am)
OnlineOnline
Has thanked: 740 times
Been thanked: 2355 times
think off it logically
i am 1.75 tall x400x600 roughly and dont have to stoop or walk through doors at an angle or in a funny way
providing the door openings are say 660mm/2ft3" wide i cant see a problem even approaching from an angle
public stairwells tend to be wider wider than domestic so if you can get it to the front door your sorted
tadaska (Thu Mar 18, 2021 1:36 pm)
Gadget
Jack Of All Trades
Has thanked: 347 times
Been thanked: 343 times
Post by Gadget »
big-all wrote: Thu Mar 18, 2021 12:49 pm think off it logically
I sometimes walk through doors at an angle and in a funny way, but that's when I've had a Scotch or two too many.. :lol:
By eck! ©
Gadget wrote: Thu Mar 18, 2021 10:51 pm
that because the room keeps moving often in a wibilly wabbly way :huray:
Gadget (Thu Mar 18, 2021 11:16 pm)
arco_iris
Has thanked: 184 times
Been thanked: 535 times
Post by arco_iris »
If you are ordering online from DIYK (been there done that*) you can specify (as you raise the order for each item) for particular units to be flat-packed due to access issues, then glue them yourself on site, it's not rocket-science. Just add a note to the item on the page & they follow the instruction.
For instance, I knew I would have issues with a couple of carcases to modify, specified "no glue" and although they were delivered assembled, they knocked apart easily, did my bits (cooker hood & duct cutouts) then glued the joints back together.
* Customer Service Aftersales has been excellent.
tadaska (Fri Mar 19, 2021 7:28 am)
Return to “Kitchen Fitting”
