Shared neutral?
roofmonkey
Shared neutral?
Post by roofmonkey »
I was changing a light fitting today, I switched off the circuit breaker for the lighting but when I touched one of the wires (not sure witch one) the power circuit switched off. I am thinking that a shared neutral could be the issue here. Can I leave it or could it be dangerous if it is a shared neutral. Obviously locating the connection could be a real nightmare. Thanks for any help.
Has thanked: 736 times
Been thanked: 2341 times
Shared neutral?
2 way lights on stairs will be powered at one end from the apparent "wrong "circuit
was this on a stair or landing ??
Has thanked: 47 times
Been thanked: 2590 times
Shared neutral?
roofmonkey wrote: Fri May 14, 2021 3:36 pmI switched off the circuit breaker for the lighting, the power circuit switched off.
If it was off how could it switch off again?
I would guess you mean the RCD tripped? If so chances are you touched a neutral to earth, this would cause the RCD to trip, but it is nothing to worry about.
roofmonkey
Shared neutral?
Thanks very much. You put my mind at rest.
Return to “Lighting”
