House TV instalation.
- Has thanked: 13 times
I have a broadband connection to my house but wish to besides at the broadband point to receive TV in 3 bedrooms without having to run cables all over the place. Please if you can tell me how I can accomplish this.
Alfie
Alfie
- Has thanked: 47 times
- Been thanked: 2600 times
Are you asking how to have 3 TV's connected to your router?
If so you need to connect each TV via wi-fi. (Not all TV's have wi fi)
- Has thanked: 827 times
- Been thanked: 3601 times
You can use wireless extenders which use the copper wire in your home's electric circuit to send the signals from your router via ethernet connections. These extenders plug into a socket near the TV and plug into a smart TV or a Firestick to give you connections. These are what you need https://www.currys.co.uk/gbuk/computing ... dapter-kit You will need two packs of two. One for the router, one each for three TV's plus the ethernet cables. I have used these for years.
Have a search for 'TP Range Extenders' they are available in lots of places. See if this Argos link works https://www.argos.co.uk/product/5742734 ... nk:14:32:1
- Has thanked: 1300 times
- Been thanked: 1175 times
If you're just talking about "normal" Freeview via an aerial, rather than TV via the internet, then the best solution is to split the aerial using something like this.
https://www.screwfix.com/p/labgear-4-wa ... tter/89218
Running aerial cables to the separate TVs is a pain, but it works.
We have a wireless sender for video that takes the video signal from a PVR and sends it to the kitchen telly.
It works, but it's very prone to interference.
That's the actual video signal from a scart socket though rather than the aerial signal.
The TV in another room, which only gets occasional use, works fine on an indoor aerial. That depends where you are in relation to the transmitter though.
No, not "special" Tvs but ones that can connect to wi-fi, not all TVs can. So you could have what ever TV you like, but unless it has wi-fi and a wi-fi signal, no picture for you.
I honestly think you would be better off with either freeview or free sat, as if you have 3 tvs all on wi-fi, all on at the same time it may slow your wifi down for all of them.
- Has thanked: 118 times
- Been thanked: 217 times
If your TVs have Ethernet points and your WiFi isn’t great you may need to try power line adaptors but for the best solution running cables from the router to each of the TVs is best
Remember, your internet speed coming into your house will have a huge effect on the quality of the pictures if you want to use 2 or more TVs at once
