Battery drills. They are (basically) rated according to their torque - usually given in Newton-meters - with the cheaper ones being sub-40Nm and top end well over 100Nm.
But what's adequate? I know that if my current battery drill isn't up to the torque I get the corded version out but I've never had much opportunity to compare good/bad torque jobbies and I want a battery version to cover both needs.
A typical no-name (£40-ish) can deliver 30Nm, an Einhell (£100-ish) does 60Nm and top end brushless Makita (£320
Now I don't want my arm ripped off at the elbow when stalling a drill so the Makita is out - never mind the cost! and some no-names I've used couldn't twist wool into a thread - they are all 18V BTW - but what torque have 'you' found to be more than adequate for everyday drill use? i.e. mostly <10mm steel drilling, max 25mm wood drilling and 4" - 5" pozi's into 4"x2"???
Reliability and battery life don't count in this case (I'll just buy the batteries I feel I need to cover the usage and this isn't for 24/7 use, just your keen DIYer) so rather than argue competing names, what would be a reasonable expectation for torque to cover these needs?
Armed with a torque requirement I can go searching for whatever then fits the finances and see what deals they do on batteries etc.
PS - I don't wear Wranglers or Levi's or Adidas - it's 'jeans' or 'trainers', they're all the same to me - just so you know what you're dealing with
