Currently renovating a 120 year old stone wall terrace. Damp situation isn’t too bad in the house. Some rising damp that pretty much ends at skirting board level. Ive knocked that off. I have already put some self levelling down on the floor as it was all over the place but now I’m consudering whether to put down a liquid DPM before second lot of self levelling. Fairly belt and braces stuff as I’m battening all downstairs walls to dry line. Therefore rising damp up those walls isn’t too much of an issue until it attacks the battens (which I can DPM anyway).
My question is, is it worth liquid DPM the floor and if so what sort of product would people recommend?
Liquid DPM
- aeromech3
- Has thanked: 177 times
- Been thanked: 665 times
Liquid DPM
Self levelling screeds need a DPM at some point below them, other wise they will likely de-bond due to rising damp. Don't know where this leaves you, as you did not mention the type of floor or primer before your first application of self levelling. See this old thread:-
viewtopic.php?t=55086
Liquid DPM
I did 2 Coates of CEMENTONE SBR primer. Would you suggest now a layer of liquid DPM then another layer of self levelling?
Confused with the products though. Done are like emulsion and others you initially trowel I’m therefore seem a lot thicker
- aeromech3
Liquid DPM
Whilst this sounds good, firstly what SL have you used already? Most liquid DPM's are designed to adhere to a cement base and then some SL's are not good on some liquid DPM's!
Have you considered that some carpet and laminate underlays are backed suitable to act as a DPM ?
When you think about commercial buildings, a concrete based slab is put down maybe +10 to 15cm; the builders are not going to wait months to progress, no, for carpet and laminate they put another barrier a damp proof underlay, yes it effectively seals in the moisture in the slab but that is what they get away with.
