Which light switch is which?
tadaska
Has thanked: 227 times
Been thanked: 11 times
Post by tadaska »
I bought 3 light switches, 2 supposed to be double (whatever that means) for my hallway and one single for my kitchen.
The bag in the pic without a switch had a double which I fitted in my hallway and it's working fine.
I was going to fit the single switch in my kitchen next but it looks just like the double I still have to fit at the other end of my hallway.
What's going on here?
The packets say single and double but they both look the same.
Bob225
Has thanked: 105 times
Been thanked: 878 times
Post by Bob225 »
They are 1 gang (one switch) - the one on the right is 2 way (used in 2 way switching) 3 screw terminals and the one in the middle is 1 way (a basic on/off switch) 2 screw terminals
The large packet is a 13 amp double socket
tadaska
Post by tadaska »
Bob225 wrote: Fri Jul 23, 2021 10:46 am They are 1 gang (one switch) - the one on the right is 2 way (used in 2 way switching) 3 screw terminals and the one in the middle is 1 way (a basic on/off switch) 2 screw terminals
I think I've mixed it all up :D
I've got 2 white bags and one blue (middle), ignore the socket bag.
I used one from a white bag for the hallway.
I have those 2 left, one is from the white bag and one is from the blue.
But they look the same. How do I find out which is for the hallway and which is for the kitchen?
tadaska
Post by tadaska »
Anyone?
It looks like they are both 2 way even though one of them came from a 1 way bag. Unless I'm wrong and one is 1 way but visually I can't tell which one it is.
If they are both 2 way can I use a 2 way as a 1 way switch?
I really want to get those switches done today.
Neelix
Has thanked: 118 times
Been thanked: 215 times
Post by Neelix »
Are you sure you should be dabbling with electrics?
Has thanked: 47 times
Been thanked: 2590 times
If you are sure they are both 2-way then you can use either as 1 way.
You use the Com and 1 way terminals.
tadaska (Fri Jul 23, 2021 12:51 pm)
tadaska
Post by tadaska »
Someone-Else wrote: Fri Jul 23, 2021 12:20 pm If you are sure they are both 2-way then you can use either as 1 way.
Thanks, all sorted, except for one socket, it's going to need back box savers. But at least it's all connected and working.
Bob225
Post by Bob225 »
They use the same moulding for both 1 and 2 way - 1way will have 2 screws and the 2 way will have 3
Return to “Lighting”
