Is this ready to paint?
catfan331
Post by catfan331 »
Hi all, really need some help please.
Had our ceiling plastered Wednesday, 2 weeks ago. Was covering some quite thick artex so apparently had to be applied thickly.
It’s dried a lot since, but not sure if it is ready to paint?
Any help much appreciated - thank you!
yartin
Has thanked: 145 times
Been thanked: 129 times
Post by yartin »
Didn't they try to remove sharp edge?
I had mine done several months ago, I was told either bonding then skim or remove sharp edges to near flat as possible then only skim which I did, was hard work.
Thick skim takes long time to dry. The colour should be light pink and uniform when fully dry. leave windows open. You say 2 weeks ago?! I guess they applied 2 coats at least or even 3, waiting for few hours between coats. Then again I am no expert, just saying what I saw when they did mine, 2 coats and 3 hours between coats.
Christian Taylor
Has thanked: 2 times
Post by Christian Taylor »
looks almost ready to me just make sure walls are sanded evenly and then fill anything after the first coat
wes56
Has thanked: 6 times
Been thanked: 187 times
Post by wes56 »
Hard to know what to say because the photo isn't very clear, but it looks like a very poor job if a plasterer did it.
Skim properly applied in two coats with min water dries much more evenly than that.
For instance, the outside corner skim bead has not been properly covered - its grinning through.
One way to deal with Artex is to first apply bonding and then skim over the bonding - which often lowers the ceiling by a good few mm's - lowered enough anyway, to need tape or scrim at the wall/ceiling abutments.
Return to “Plastering Forum”
