- Ultimate Handyman Forum Index DIY Forum/Home improvement Carpentry/Joinery Forum
- It is currently Tue Apr 22, 2025 8:53 am
Fixing a hinge hole you've made a mess of
- Has thanked: 125 times
Post by ultimatenonhandyman »
Apologies for the rubbish pics, hopefully you get the idea.
Replacing a cabinet door and have made several attempts as couldn't get the thing straight and now the screws won't screw in to the hole properly (are loose). How do i sort it? the bottom two photos are of holes that I haven't ruined.
- IMG_20210915_184849(1).jpg (239.05 KiB) Viewed 2022 times
- IMG_20210915_184952.jpg (239.5 KiB) Viewed 2022 times
- IMG_20210915_185005.jpg (239.26 KiB) Viewed 2022 times
ultimatenonhandyman
- Has thanked: 32 times
- Been thanked: 817 times
go to screwfix and buy some hinge repair plates. doing anything else will be a waste of time
- These users thanked the author fin for the post:
- ultimatenonhandyman (Thu Sep 16, 2021 6:52 pm)
fin
fin
Thanks, buddy. Are there any particular type of screws I need to use?
ultimatenonhandyman
- Gadget
- Jack Of All Trades
- Has thanked: 347 times
- Been thanked: 345 times
They come with the screws supplied.ultimatenonhandyman wrote: ↑Thu Sep 16, 2021 6:53 pm Thanks, buddy. Are there any particular type of screws I need to use?
- These users thanked the author Gadget for the post:
- ultimatenonhandyman (Fri Sep 17, 2021 3:22 pm)
By eck! ©
Gadget
the plates come with the small screws to attach to the cabinet. then you use the screws on the hinge plate to attach that to the repair plate
- ultimatenonhandyman (Fri Sep 17, 2021 3:21 pm)
fin
ultimatenonhandyman
Probably a stupid question but here we go.
Is the reason this cupboard won't align properly because of the holes? If I put a bit of draught excluder in the hole the screw goes tight, was thinking as a permanent measure could just glue the screws in with No More Nails. Or is there another reason? I've tried adjusting the height things on the hinge holes, nothing works.
- IMG_20210918_191926.jpg (233.24 KiB) Viewed 1941 times
- IMG_20210918_191904.jpg (234.83 KiB) Viewed 1941 times
- IMG_20210918_191846.jpg (233.27 KiB) Viewed 1941 times
- IMG_20210918_191843.jpg (237.5 KiB) Viewed 1941 times
ultimatenonhandyman
- arco_iris
- Has thanked: 184 times
- Been thanked: 535 times
Have you tried LATERAL adjustment of the hinges? Top one in, bottom one out. A cabinet hinge has THREE adjustments.
Up and down is the screws that hold the mounting plate to the repair plate.
In and out is the screw at the back.
LATERAL is a screw that is hard to see unless you know these things - there's a hole, or slot, in the hinge body, sometimes it has a little cover clipped into it, if so, pop that off. Put a cross head screwdriver into the slot & locate the screw head - turn the bottom one anticlockwise and the left hand side of the door will lift (when closed). Turning the top one clockwise will cause the top of the door to move to the right and the bottom left corner to lift (when closed). The gap between the two doors will alter - it might be one adjustment or the other to get it as you want it to look.
Let us know!
Let us know!
- These users thanked the author arco_iris for the post:
- ultimatenonhandyman (Sun Sep 19, 2021 7:50 am)
arco_iris
I'll give that a try, thanks very much
ultimatenonhandyman
absolutely you need the hinge repair plates. putting any kind of glue into the screw holes then putting the screws in will not work whatsoever. they come as a pack of 2 so use on both hinges. then adjust the hinges as necessary
- ultimatenonhandyman (Sun Sep 19, 2021 4:44 pm)
fin
ultimatenonhandyman
Awesome stuff, worked a treat. But now I have another questionarco_iris wrote: ↑Sat Sep 18, 2021 7:39 pm Have you tried LATERAL adjustment of the hinges? Top one in, bottom one out. A cabinet hinge has THREE adjustments.
Let us know!
ultimatenonhandyman
- arco_iris
READ MY POST AGAIN!
To move whole door backwards when closed, it's the screw at the rear of the hinge - slacken it only slightly, with the door open, and push the door back towards the cabinet then tighten. If you go too far, the door will foul the carcase as you go to close it.
A good way is to put a credit card between the door open at 90° and the cupboard side, adjacent to hinge you're adjusting, move door until they meet, tighten screw. This will give 1mm gap between flat closed door & cabinet.
- ultimatenonhandyman (Sun Sep 19, 2021 6:32 pm)
arco_iris
A god among men, you are, mate. A god among men
ultimatenonhandyman
