Alarm Systme PIRS Stuck On
Has thanked: 47 times
Been thanked: 2575 times
somhairle wrote: Sun Sep 19, 2021 6:03 am All works as it should but the PIR remains lit at all times. Not the LED.
:huh:
But it is the LED that illuminates
Since none of us are there, how about a picture?
somhairle
Has thanked: 96 times
Been thanked: 3 times
Post by somhairle »
Solution:
Disconnected the zone 3 PIR and left for a few minutes before reconnected power to it. All now working.
If you had of done what I asked, when I asked it, you could have had it working days ago.
Also next time, or who ever you ask, please do as asked, don't say one thing, decide it is wrong and expect anyone trying to help you, to know what you have said is wrong.
mudmouse wrote: Fri Sep 17, 2021 5:54 pm what is the LED remaining on?
somhairle wrote: Fri Sep 17, 2021 6:00 pm It is the first one (zone 1)
somhairle wrote: Sat Sep 18, 2021 10:40 ambut not the PIR on zone 3 which is still on.
See how confusing it is.
somhairle
Post by somhairle »
Someone-Else wrote: Tue Sep 21, 2021 4:44 pm If you had of done what I asked, when I asked it, you could have had it working days ago.
You missed a bit before the extracts you quote. I never mentioned a fault with the LED. It was only the PIR. That was unfortunately picked up incorrectly and I responded incorrectly not noticing the mistake.
In an effort to clarify things, as you requested, I did summarise it in some detail, hopefully correcting any confusion. Unfortunately it didn't. But thanks for your help. It was useful.
However, it is working now and to clarify, it worked by disconnecting the power wires to the PIR, leaving it for a few minutes and then reconnecting.
Once again, thanks for your help and also mudmouse.
Return to “Electric Forum UK”
