Hotpoint Oven - No Power
97browng
Has thanked: 2 times
Been thanked: 5 times
Post by 97browng »
Hi All,
About an hour ago I was cleaning my electric oven (Hotpoint Class 7 SI7 891 SP IX) and when I went to wipe the bulb cover the bulb went off and then so did the oven. The bulb was very hot (too hot to hold) and had only been on for a few minutes. Since then I have been unable to get the oven back on. I have ordered a new bulb for tomorrow and will test that but I assumed the oven would work if the bulb was removed (but it is not). I have tried the below, is there anything else I can check myself?
Removed the bulb
Check the house fuse box (nothing tripped)
Checked the fuse on the oven plug (it is just a standard UK 3 pin plug going into a normal single socket). I replaced with a know working 13a fuse.
Checked another wall socket
Thanks in advance
Gary
Grumps
Location: Worcestershire/Warwickshire/Gloucestershire (ish)
Has thanked: 51 times
Been thanked: 152 times
Post by Grumps »
Hi.
Not a topic for the site.
You need to go to the UK Whitegoods forum.
https://www.ukwhitegoods.co.uk/forums/f ... oven-forum
The site is both a Forum and a parts supplier (at competitive prices).
The two sites are not in competition. In fact, if you commence your question with the information that you have been directed there from UHM, then such may assist traffic to UHM. :wink:
97browng
Post by 97browng »
Thanks for the response. I have created a topic there :)
Grumps
Post by Grumps »
I see you are getting assistance from someone at UK Whitegoods. They obviously know their stuff. :huray:
Good luck. :thumbright:
Return to “Electric Forum UK”
