Hi Guys
I’m wanting to put power to my garage would I need armour cable for the run or just the bit that goes from the garage to the house approximately 6m where it enters into the loft, then join with twin and earth to the CU. (I live in a bungalow)
Thank you for your help
R0nin
Cable
- Has thanked: 47 times
- Been thanked: 2575 times
Cable
The more joints a cable has the more chance to go wrong.
- Has thanked: 820 times
- Been thanked: 3519 times
Cable
I have a similar connection from my garage to outbuildings for power and light. The armoured cable is fitted to a fused spur in the garage and fused isolation switches at the other end.
- Argyll
- Has thanked: 1180 times
- Been thanked: 580 times
Cable
I used 20m of 6mm2 SWA attached via a catenery cable about 12ft above my head into my house. I could have used this stuff to save more money:
https://www.cef.co.uk/catalogue/categor ... thed-cable
If it's just for 6m I'd use the tuff stuff.
By the way I'm not an elctrician. Most of the advice I received on here last year while I was doing mine.
