Old Red/Black Cable
Onar
Has thanked: 16 times
Been thanked: 2 times
Old Red/Black Cable
Post by Onar »
Hello,
I have discovered a 100 ft Roll of 2.5mm Twin/Earth cable (Pre EU/UK) tucked away.
It is the Red/Black.
Now we have left the EU would it be legal to use it in my own garage?.
Thank you.
arco_iris
Has thanked: 184 times
Been thanked: 535 times
Old Red/Black Cable
Post by arco_iris »
I expect the professional electricians on here will have comment to make, but to the best of my knowledge, BS7671 - the wiring regulations, which are not law - does not specifically say it can't be used.
However, if the rest of your house is already in the new "harmonised" colours, you should technically put a sticker on the consumer unit that says mixed colours are in use in the building, you can get these online in small packs. It works the other way, you see, when you can only purchase new spec. cable to do a repair in an old building.
Alternatively, you can buy yourself some blue sleeving & some brown sleeving and slide this over your black/red inside each socket backbox, light switches, and junction boxes. I believe this would make it compliant.
The pros are under pressure from their trade/certification bodies to use the new colours so where you might come up against aggro is if your installation needs to be tested & officially certified.
ericmark
Has thanked: 118 times
Been thanked: 785 times
Old Red/Black Cable
Post by ericmark »
There is no reason even before we left EU that it should not be used and sleeved.
These users thanked the author ericmark for the post:
Argyll (Wed Dec 29, 2021 5:43 pm)
Neelix
Been thanked: 219 times
Old Red/Black Cable
Post by Neelix »
Over sleeving is largely irrelevant. Red & black was the correct colour to be used IMHO.
As for anybody commenting its a bad idea and not compliant - show them the door.
Has thanked: 48 times
Been thanked: 2608 times
Old Red/Black Cable
You might want to sell it on ebay.
Argyll
Has thanked: 1194 times
Been thanked: 584 times
Old Red/Black Cable
Post by Argyll »
ericmark wrote: Wed Dec 29, 2021 4:08 pm There is no reason even before we left EU that it should not be used and sleeved.
I wish I'd known this when I forked out on a new reel last year when wiring my shed. I have a full reel of the old stuff that someone told me I couldn't use 😒
Old Red/Black Cable
How would anyone know if you used it in your own place? But same advice, sell it on ebay, its not quite silly money but I bet its much more than you paid for it.
Argyll
Old Red/Black Cable
Post by Argyll »
Someone-Else wrote: Wed Dec 29, 2021 5:53 pm How would anyone know if you used it in your own place? But same advice, sell it <span class="skimwords-potential">on ebay</span><span style="position: absolute;"></span><span style="position: absolute;"></span>, its not quite silly money but I bet its much more than you paid for it.
I just thought as it's connected to the CU and if I ever sell my house it might be highlighted on the report so thought it best to play safe. I need to rewire my kitchen at some point. I might use it with the new sleeving.
Onar
Old Red/Black Cable
Post by Onar »
Thank you for all your comments.
I will check with some organisations.
arco_iris
Old Red/Black Cable
Post by arco_iris »
Quite likely - but weighty, so carriage/postage to take into account.
Argyll, as Neelix didn't object as I thought he might, just use it and apply a sticker.
Argyll (Wed Dec 29, 2021 11:01 pm)
Chippo1
Has thanked: 10 times
Been thanked: 194 times
Old Red/Black Cable
Post by Chippo1 »
The only real issue is , will the cable pass a test ect
Other than that label CCU , mine is labelled for this reason
kellys_eye
Has thanked: 357 times
Been thanked: 1790 times
Old Red/Black Cable
Post by kellys_eye »
What kind of useless electrician WOULDN'T recognise red/black as opposed to brown/blue FFS? How is the different colour supposed to be 'dangerous'? This is akin to a garage mechanic not knowing the difference between petrol and diesel.
Razor
Has thanked: 483 times
Been thanked: 1251 times
Old Red/Black Cable
Post by Razor »
Old coloured cable goes well on ebay.
It means tradesmen that aren't sparkles can fit new circuits and claim it was existing :wink:
Neelix
Old Red/Black Cable
Post by Neelix »
As a spark I’m expected to add a warning label on a fuseboard if both old and new colours are used.
After about 18 years since the colour change we need to stop adding POINTLESS labels - I stopped a few years ago
If you don’t know that red is live or brown is live you deserve to hurt yourself
Argyll
Old Red/Black Cable
Post by Argyll »
Neelix wrote: Wed Dec 29, 2021 10:27 pm As a spark I’m expected to add a warning label on a fuseboard if both old and new colours are used.
For the non sparks out there it's easy to remember 'black and blue'
Return to “Electric Forum UK”
