Garage c/u question
Sparky70
Has thanked: 157 times
Garage c/u question
Post by Sparky70 »
Hi all,
I currently have a dedicated 20a mcb on my consumer unit in the house that goes to a switch on the inside of my house which then supplies what looks like SWA 2.5mm t & e and that goes to my garage underground and then terminates in the garage at a fused switch. I've checked the fused switch as this is fused only for a light in the garage and there is also another 2.5mm t & e cable which is connected on the live and neutral side which goes to a double socket. My question is can a small garage consumer unit be installed instead of having the metal fused switch and if so which one would be suitable seeing as I already have a 20a mcb with RCD protection from the domestic c/u. I was thinking of just a mains switch with a 6a mcb for lighting in garage and a 16a mcb for the socket. I would like to install another socket from the existing one if possible.
Has thanked: 47 times
Been thanked: 2575 times
Garage c/u question
Yes you can do as you suggest, the consumers unit would be your choice, but you want one without an RCD
Sparky70 (Sat Jan 08, 2022 7:34 pm)
Sparky70
Garage c/u question
Post by Sparky70 »
Many thanks Someone - Else, I will do that then, will add another double socket too and leave it as a radial.
Neelix
Has thanked: 117 times
Been thanked: 214 times
Garage c/u question
Post by Neelix »
Why are you wasting money on a small fuseboard?
Sparky70
Garage c/u question
Post by Sparky70 »
Neelix wrote: Sat Jan 08, 2022 10:29 pm Why are you wasting money on a small fuseboard?
Because I already have a 2.5mm and two 1.5mm t & e in the metal fcu and I need another light switch at the other end of the garage so thought it would be best to upgrade due to the amount of cabling.
Sparky70
Garage c/u question
Post by Sparky70 »
I suppose I could just use an IP55/65 junction box instead to reduce costs ?
Neelix
Garage c/u question
Post by Neelix »
Sparky70 wrote: Sun Jan 09, 2022 11:37 am
I don’t understand why you think you need an enclosure at all
Sparky70
Garage c/u question
Post by Sparky70 »
Neelix wrote: Sun Jan 09, 2022 1:03 pm
I have a 2.5mm swa cable going into the garage and it terminates into a metal switch fcu, the light in the garage is connected to the the fused switch and the sockets are connected directly to the incoming side along with a 1.0mm cable on the incoming side to a fused switch 1amp for 2 led floodlights. so there's currently 3 x cables in this fused switch. What i'm trying to achieve is to have another light switch ( 2 way ) at the other end of the garage and another (2 way ) near the existing fused switch, I'll be installing to new led light battens and I want to have control at either end of the garage, I will also add another socket from the existing socket, do you have any recomendations to achieve this ? regards.
Neelix
Garage c/u question
Post by Neelix »
Sparky70 wrote: Sun Jan 09, 2022 4:58 pm
You’ve moved the goal posts a lot now …
Sparky70
Garage c/u question
Post by Sparky70 »
Neelix wrote: Sun Jan 09, 2022 8:07 pm
ericmark
Been thanked: 783 times
Garage c/u question
Post by ericmark »
I would change the FCU to a double back box and LAP grid fuse and switch from Screwfix so I can fit a two way switch and also 2 fuses if I want with a little more room to work in.
Similar to as done here
to fuse and extend a spur.
These users thanked the author ericmark for the post:
Sparky70 (Tue Jan 11, 2022 8:33 pm)
Sparky70
Garage c/u question
Post by Sparky70 »
ericmark wrote: Tue Jan 11, 2022 7:51 am I would change the FCU to a double back box and LAP grid fuse and switch from Screwfix so I can fit a two way switch and also 2 fuses if I want with a little more room to work in.
Similar to as done here IMGP7387.jpg to fuse and extend a spur.
That's a good idea, many thanks Ericmark
Return to “Electric Forum UK”
