When would you use different corner beads?
Argyll
Has thanked: 1188 times
Been thanked: 583 times
Post by Argyll »
I've noticed there are several different types of corner beads. I'm looking for one to attach to a stud corner. Which one should I use and why are there different types?
OnlineOnline
Has thanked: 826 times
Been thanked: 3592 times
I would use the left hand one for plasterboard corners
Argyll (Tue Feb 08, 2022 8:12 pm)
arco_iris
Has thanked: 184 times
Been thanked: 535 times
Post by arco_iris »
Agree with DWD. Thin, to hide under the skim, sometimes called a pro-bead.
The middle one is for solid walls, skimmed a little thicker, the mesh enables it to be bedded in place in advance of getting to the corner.
The right hand one is a render bead for sand & cement.
Argyll
Post by Argyll »
Brilliant thanks guys. I chose the left one as I usually do but didn't really know why 😄
OnlineOnline
Return to “Plastering Forum”
