Good evening.
I was using my carpet cleaner at my brother’s flat. After a while it kept tripping the RCD switch.
I’ve used it in my house and my mother’s without incident; does this suggest a problem with my brother’s flat?
RCD trip - carpet cleaner
- Has thanked: 17 times
Yes, sorry I didn’t write enough information.
Subsequent to it tripping the RCD in my brother’s flat, I’ve used it in my house, which also has an RCD, without any tripping.
- Has thanked: 117 times
- Been thanked: 214 times
I would say that your brothers house may have a problem with the socket circuit OR the actual RCD may be more sensitive than it should be - which is quite common.
If its the only thing to trip his RCD I would say leave it, but if other devices trip the RCD then some investigation is required
