Raking on gravel - help!
- Has thanked: 2 times
I have a hedge between my house and next door, which needs trimming every so often. Our front garden now has granite chipipngs (had to remove the grass due to chaeffer bugs). This is fine, but means that when I've trimmed the hedge, raking up the cuttings is a nightmare as I end up just raking the chippings/gravel.
Can anyone advise a good way to rake up the trimmings easily?
- Has thanked: 1414 times
- Been thanked: 4015 times
Put a tarpaulin or similar down before cutting the hedge.
- Has thanked: 807 times
- Been thanked: 3496 times
This is where a blower vac is handy. I blow the cuttings to asphalt and vacuum up there, works for me on gravel. See https://www.screwfix.com/p/mac-allister ... /404fg#_=p
dewaltdisney wrote: ↑Thu Jun 16, 2022 1:44 pm This is where a blower vac is handy. I blow the cuttings to asphalt and vacuum up there, works for me on gravel.
Tarpaulins are cheaper...
Thanks. You don't find the blower vac blows the gravel or are they not that powerful?dewaltdisney wrote: ↑Thu Jun 16, 2022 1:44 pm This is where a blower vac is handy. I blow the cuttings to asphalt and vacuum up there, works for me on gravel. See <span class="skimlinks-unlinked">https://www.screwfix.com/p/mac-allister ... #_=p</span>
You soon get the distance sussed, you have enough blow for the leaves but not the gravel about 9 to 12 inches from nozzle to ground.
They are handy for lots of garden jobs
- Has thanked: 47 times
- Been thanked: 2556 times
Is using a blower / vac not making more work? Since you have to then get said vac, use it and empty it, but a tarp all you do is collect its 4 corners and take it and shake it into the bin
- Has thanked: 201 times
- Been thanked: 499 times
Personally I do a mix of the both. Sheets down which catch most of the cuttings and as said can be lifted into the bin and then much less to blow into a pile.
Personally I find gravel horrible stuff in a garden and don't worry in the slightest if some of it ends up in the bin.
