Black Mold
Onar
Has thanked: 16 times
Been thanked: 2 times
Black Mold
Post by Onar »
Hello guys,
I have found Black Mold on areas of silicone around my bath.
I have tried vinegar, bleach, baking soda etc.
Nothing has worked so far.
Can anyone offer any advice on this please?.
Thank you.
Has thanked: 824 times
Been thanked: 3565 times
Black Mold
Try this it is quite effective https://hg.eu/uk/products/hg-mould-remover-foam-spray I saw it in Tesco the other day. I have used it for years.
adonis
Has thanked: 30 times
Been thanked: 121 times
Black Mold
Post by adonis »
This stuff is good as well, you can get it in various shops.
[https://www.wilko.com/en-uk/cillit-bang ... /p/0412312][/url]
Rorschach
Has thanked: 112 times
Been thanked: 1041 times
Black Mold
Post by Rorschach »
If bleach doesn't work then you need to replace the silicone. All mould cleaners are based on bleach and are just rebadged and expensive versions of the cheap stuff you stick in your toilet.
Paint on some thick bleach, leave it sit for a few hours, if that doesn't work, nothing will.
tictic (Fri Jun 10, 2022 7:17 pm)
Black Mold
Well, whilst this might be true I have found that the HG works far better than household bleach. Perhaps it is a stronger concentrate?
Rorschach
Black Mold
Post by Rorschach »
HG is about the same strength as most "thick" bleach you can buy. It is stronger than thin bleach but it's not just strength that matters, it's contact time. You can simply apply thin bleach 2 or 3 times and still save yourself an awful lot of money or just use the thick bleach (you can't spray that though). There are also (slightly dangerous) ways to make bleach more effective but that needs to be done with extreme caution and excellent ventilation.
Black Mold
That will save £4 then R :lol:
tictic
Has thanked: 5 times
Been thanked: 23 times
Black Mold
Post by tictic »
Cheap silicone been applied…remove it all clean then apply a silicone that’s best for the job
Onar
Black Mold
Post by Onar »
I tried both bleach and vinegar, I was anxious to get rid of it.
So I tried HG as Dewaltdisney mentioned.
HG did a wonderful job after multiple applications leaving mold covered with kitchen towel to allow soaking.
Thanks to all for advice.
