Turning door and casing want to check
- Jaeger_S2k
- Pro Handyman
- Has thanked: 20 times
- Been thanked: 27 times
I've got to turn a door round in the office with the shelves where the shelves where built.
I'd like to check my plan?
Remove door.
Remove architrave.
Strap bottom of door casing by pinning a piece of wood across, to hold casing square.
Remove fixings and any packers.
Turn casing and fit packers and ensure vertically true.
Fix casing, fixing through or close to packers.
Rehang door.
Refit architrave.
Repair any plaster around architrave.
Done.
Remove door.
Remove architrave.
Rehang door.
Refit architrave.
Done.
Jaeger.
- Has thanked: 16 times
- Been thanked: 9 times
- Jaeger_S2k
- Pro Handyman
- Jaeger_S2k
- Pro Handyman
- Has thanked: 736 times
- Been thanked: 2341 times
before you remove it check the frame for how out of square it is
if the door /frame leans to the side by say one inch top to bottom when you turn it round it will be 2 inches out if you move it to average the gap around the frame you would have to cut 1/2 inch off the skirting one side then add 1/2" the other side
basicly what i am saying is it could be more difficult than it first seems
requiring hammer and chisel and spare skirting ect
another point to consider your colour scemes will be transposed on the door
- dirtydeeds
- Craftsman Carpenter
- Jaeger_S2k
- Pro Handyman
OK. Door and casing turned.
Mad half hour trying to work out why the door (on the lock side) was flush fit at the bottom and up about 12" then leaned away from the jam, leaving a slither of a gap (which slithered to about 1/2" ) at the top.
Check and check and check,
Casing square (Check)
Casing Plumb (Check)
After scratching head, saw the door from a distance, it was warped!
The swap went quite well and was a good experience. The case was packed at one side and not the other, so some skirting was trimmed (MultiMaster to the rescue) and the floor covering varied too so needed trimming one side, I'll be packing and filling the other later.
All in all I'm pleased with it so is the client, will get photo's on next visit.
Thanks to all who responded.
Jaeger.
