rail/track saw options
- Has thanked: 11 times
- Been thanked: 3 times
I was looking at an entry level track saw or rail saw (not sure what is the best name) and I was eyeing the Evolution R185CCSX+ as it seems to be a interesting DIY option. The saw cost £90, the 2800mm tracks cost £77, but when I started checking the reviews of the track, it seems to be crap, not accurate. As I'm planning to start doing a lot of DYI and get more into woodwork, I was hoping to get something that is not crap, but also not expensive. Is there something decent around the £150-£250 mark for a saw + track of decent size or should I be aiming at a lot more?
- Razor
- Has thanked: 483 times
- Been thanked: 1251 times
As UHM hasn't done a comparison I will direct you to Peter Millards youtube channel. He has many videos and unbiased reviews of tracksaws and is a very chilled guy...
https://www.youtube.com/watch?v=ZCVPNFeHAQ8
- Has thanked: 734 times
- Been thanked: 2335 times
a true plunge saw will give better results but will cost more the saw you link to dosn't plunge in action
I've watched lots of his videos now, thanks for pointing it out :)Razor wrote: ↑Tue Aug 09, 2022 6:46 pm As UHM hasn't done a comparison I will direct you to Peter Millards youtube channel. He has many videos and unbiased reviews of tracksaws and is a very chilled guy...
That is a good point, I'm considering plug saw as an option now. Do you have any recomendations It seems ebauer could be a good option at £160. I would love a festool, but for £450, I guess that my DIY projects would not make justice to it.
i can only speak for for dewalt as thats what i have i have a 15 year old[ish] 18v and the rather more expensive 54v flexvolt battery plunge saws pretty much identical apart from battery and motor so a good design
i dont have a mains one
as an aside the 18v was £100 for saw and £100 for 2 tracks and joiners plus vat and as that was 17.5% may have been even longer lol
- Has thanked: 32 times
- Been thanked: 805 times
im pretty sure with the erbauer saw..... screwfix certainly dont seem to sell the same sized replacement blade. and when i had a look for a friend of mine that owns one i struggled to find a similar sized blade.
- Has thanked: 160 times
- Been thanked: 67 times
Lad on site has been using the makita 40v rail saw. Not a true plunge saw but its a good bit of kit quite adequate for most tasks but probably out of your budget OP
- Argyll
- Has thanked: 1180 times
- Been thanked: 576 times
I started with the Parkside I bought on a whim = crap. Then I bought the Triton = crap, then the Evolution which was okay but I took it back (can't recall why). I ended up with the corded Makita which I love. I like the 3mm tranch function which gives a cleaner cut. I have the Evolution track which is compatible split into two which makes I think 3m but I'm not impressed with it. I want to buy the 2800mm Makita track but haven't taken the plunge yet (see what I did there )
I was checking Makita options, SP6000J/2 at https://ffx.co.uk/product/Get/Makita-Sp ... ector-Case is £289, the version with 2x 1500mm tracks is £429, so that means £138 for the tracks. I wonder if the evolution tracks would be a good alternative at £77 https://www.amazon.co.uk/Evolution-Powe ... B07HRDG2JGArgyll wrote: ↑Wed Aug 10, 2022 7:12 pm I started with the Parkside I bought on a whim = crap. Then I bought the Triton = crap, then the Evolution which was okay but I took it back (can't recall why). I ended up with the corded Makita which I love. I like the 3mm tranch function which gives a cleaner cut. I have the Evolution track which is compatible split into two which makes I think 3m but I'm not impressed with it. I want to buy the 2800mm Makita track but haven't taken the plunge yet (see what I did there )
That would be more than twice the £160 I had in mind for an erbauer model, but again if I'm planning to keep it for the next 5-10 years maybe it is worth spending more... I just can't see a way to justify festool at £400+ just for the saw
Well, let's say the budget is low/mid tier, I would like toa void overspending on a overkill tool that I may use a few times a year, but also I'm considering perhaps having the tool for many years to come. In fairness I have a pair of Makita cordless drills for 15 years still working okay, just had to buy replacement batteries from ebay to keep going
- Argyll
I don't like my evolution split tracks. Even spending a lot of time assembling you'll never get them exactly straight. That's why I want to buy the 3m makitableicker wrote: ↑Sat Aug 13, 2022 11:43 amI was checking Makita options, SP6000J/2 at <a href="https://ffx.co.uk/product/Get/ ... r-Case</a> is £289, the version with 2x 1500mm tracks is £429, so that means £138 for the tracks. I wonder if the evolution tracks would be a good alternative at £77 <a href="https://www.amazon.co.uk/Evolu ... RDG2JG</a>Argyll wrote: ↑Wed Aug 10, 2022 7:12 pm I started with the Parkside I bought on a whim = crap. Then I bought the Triton = crap, then the Evolution which was okay but I took it back (can't recall why). I ended up with the corded Makita which I love. I like the 3mm tranch function which gives a cleaner cut. I have the Evolution track which is compatible split into two which makes I think 3m but I'm not impressed with it. I want to buy the 2800mm Makita track but haven't taken the plunge yet (see what I did there )
The evolution R185 saw itself is superb, I really cannot fault it.
https://www.youtube.com/watch?v=gGu9pqAB4Zk&t
(can't embed the video, as there is a problem with videos containing the & character)
The track that comes with it is 3 piece and is crap (trying not to mince my words).
However, I recently bought the 2.8M track and this makes the R185 much more usable. I did buy a special TCT blade though- https://bit.ly/3SQirXK
I’ve been using this for the last few weeks to cut Multipanels, basically veneered 11mm thick exterior plywood in 8’ X 4’ sheets- viewtopic.php?t=106960
I also cut 3 worktops using the track and saw, again with the specialist blade (doing multiple passes, as described in this thread- viewtopic.php?t=107100 )
It also cut the tall end panels and base end panels.
I’ve not tried any other make of track, but the evolution track is compatible with –
Evolution R185CCSX+ - 185mm Circular Saw
Festool TS55REBQ-PLUS and HK55
Titan TTB73CSW
Makita DSP600ZJ, DSP601ZJU and SP6000J
Bosch GKS55GCE and GKS65GCE
Triton TTS1400
Erbauer ERB690CSW
Metabo KS55FS
Scheppach PL45
This video was just made live today-
Plunge saws are probably much better suited if you have a lot of kitchens to install etc. I have not installed a kitchen for several years and only did the most recent one out of emotional blackmail
If I was installing kitchens or Multipanles for a living, I would probably invest in a cordless track system
Titan TTB73CSW
Triton TTS1400
Erbauer ERB690CSW
Metabo KS55FS
Scheppach PL45
- These users thanked the author ultimatehandyman for the post:
- bleicker (Tue Aug 23, 2022 11:16 am)
to me its the quick simplicity off the track saw
2 marks lay the track and cut 8 -12 seconds 60 whilst you learning
i actually have 4x1500mm dewalt tracks 2x 1500 and 2 cut giving 1x 995mm 1x865 1x635mm 1x500
you need around 175-225mm greater than the cut to start the saw fully on the track so 1220 sheet 1500 track
normal door in situ 768-810 1m track 600 kitcken door or worktop 865 track
the 635+500 short cuts or any combination up to 3 tracks [have 2 joiners]gives up to 4m
- These users thanked the author big-all for the post:
- ultimatehandyman (Sun Aug 14, 2022 8:54 pm)
I should have mentioned that I did buy a Kreg Accu-cut, after someone recommended it in a YouTube comment. I think I paid £80 for it, but unfortunately, it did not work well with my cordless Dewalt, so I ended up selling it for £40
The accu-cut does not need clamps to hold it down, it uses a piece of friction material to hold itself to the wood. I don’t know if it works or not, as my circular saw was not compatible with the damn thing
