Powering a garden room
- Has thanked: 11 times
Hi everyone,
I'm planning to building a garden office next year and as usual, I'd like to plan as much as I can :).
Currently, we have a small brick shed where our washing machine is located. The idea is to demolish that and build a garden room bigger, cleaner and with the right amount of ventilation.
I have some questions regarding the electrical that it will require. When we bough the house 2 years ago, there was already a connection between the house and the small shed. This seems to be a spur, coming from the inside of the house, on top of the garden backdoor and then directly into the shed.
Now, I know that a single spur won't suits my needs, however I was wondering, since the garden room and the house will be less than 1 meter apart, can I extend the internal existing ring circuit to the garden room? That would avoid the need of bringing power from the front of the house (where the consumer unit is), remove all the slabs, dig etc etc.
I am attaching a picture of current setup, to clarify what I have right now. Would it be within regs passing the cables on the top instead of underground?
I have experience on adding extra sockets within a ring circuit and I feel like I can do that, however if this would be out of regs and power from the main consumer unit is needed I'll call a pro. I just want to be sure that is the only option, cause dig for the cable from the front of the house will make this a huge job.
Thank you for your input!
- shed.jpg (801.81 KiB) Viewed 653 times
