New One on Me
- Has thanked: 814 times
- Been thanked: 3508 times
New One on Me
I watched a Youtube video that had a very interesting use for super glue. The guy was causing a chemical reaction using super glue and baking soda that forms a tough plastic when mixed. In its simplest use, he used it to pack out a worn screw hole in wood that when it had hardened he drilled a pilot and screwed in. He got more adventurous as he went on and repaired a broken plastic gear wheel forming a new section that he chemically formed on the broken section. I cannot find the original video but this is worth a look https://www.youtube.com/watch?v=ImLAmfM_AgA
It looked bloody good for knackered screw holes so I will try that when I next have that problem.
- Has thanked: 47 times
- Been thanked: 2572 times
New One on Me
To quote Star Trek's Mr Checkov "I know this trick, it was invented by a little old lady from Russia"
New One on Me
Yes, I thought that, the times I have struggled getting damaged screwheads out. I must remember to stock up on Superglue in Poundland.
