beading (wooden floor)
hache
Post by hache »
Help!! what is the angle when you are going around a door frame?? I have tried the 45 degree but they just dont join up... I dont want to waste anymore as its expensive...
Gadget
Jack Of All Trades
Has thanked: 344 times
Been thanked: 342 times
Post by Gadget »
It's 45 degrees, but if the frame isn't square then it won't join up. Check the frame is square! Also check that the mitre guide/saw or whatever device you are using is accurate! I take it your fitting architrave!
By eck! ©
ellie
BANNED
Post by ellie »
A photo would help explain your predicament.
dirtydeeds
Craftsman Carpenter
Post by dirtydeeds »
ellie
a 45 degree mitre ONLY works if the angle is 90 degrees AND the lining is EXACTLY square to the wall
if the lining isnt exaclty flush to the wall you are dealing with a compound angle
practice is the only teacher, it isnt easy and 99% of all architraves have this problem. its a fact of life
Site Admin
Has thanked: 1012 times
Been thanked: 918 times
Might be a bit late now, but it's best to go underneath the door frame if possible-
http://www.ultimatehandyman.co.uk/lamin ... frames.htm
ellie
BANNED
Post by ellie »
dirtydeeds wrote:ellie
Only asked for a photo I know how to cut miters
