I got a quote to move the consumer unit and I believe it's crazy high. What would be a fair quote?
- Has thanked: 11 times
Hi everyone,
I got a quote from an electrician to move my consumer unit, but I was in shock once they told me that it would cost over £1000!
Under the staircase there's some dead space to which you can access by opening two small doors. Currently the consumer unit is located in the middle of this dead space, leaving basically a lot of empty space behind it and making impossible to reach it. What I asked this electrician to do is simply to move it from the middle of this space just to the side wall inside the same space underneath the stairs. Isn't over £1000 a crazy price for this? We are talking about 50 or 60cm max I don't think it requires a huge rewiring. What are your thoughts?
- meter2-1.jpg (235.9 KiB) Viewed 1605 times
- aeromech3
- Has thanked: 177 times
- Been thanked: 665 times
Not about to advise but is the in coming on the wall you want it moved to?
- Has thanked: 47 times
- Been thanked: 2575 times
Get another quote.
Also make sure they are like for like. I suspect the quote is also to change the consumers unit.
As that one is low and right in the corner I can live heaving that there, but I'd like to have all the rest moved to the side so that I can use the space. I can't explain myself why someone would put it this way without thinking of leaving access to the other side
I think I will get another quote, the consumer unit seems in good state and it hasn't given any issues in 2 years since bought the propertySomeone-Else wrote: ↑Sat Dec 03, 2022 3:20 pmGet another quote.
But does the quote include a new consumers unit? (I did ask)
Oh, also you have 2 henly blocks (Big junction boxes) one cable feeds the consumers unit, what does the other one supply? and is this in the quote?
Also, just saying the electrician can not move the meter or the main fuse. That is down to the DNO (Loads of money)
The quote wasn't a detailed one as they came for a different job (connecting a new electric hob/oven and charged me £96 for putting only a cable), but they didn't speak about putting a new consumer unit, I don't really see the need for one. I'll get another quote from someone else and ask for a detailed one...Someone-Else wrote: ↑Sat Dec 03, 2022 4:03 pmBut does the quote include a new consumers unit?
Thank you all for your input, at least now I know that they wouldn't be able to move everything but I would need to ask to the DNO too
Sorry, I don't do internet quotes
- Neelix (Sat Dec 03, 2022 6:26 pm)
Ahahah I served you that so easily
- Has thanked: 117 times
- Been thanked: 214 times
So the big questions are:
1. is relocating the consumer unit necessary?
2. Where are you in the UK?
3. What spec have you been given for the new consumer unit? Dual RCD? RCBO board?
4. Has the quote confirmed that the installer will provide an Electrical Installation Certificate and Part P compliance?
5. Does the price quoted include or exclude VAT
BTW I'm a spark
BTW I'm a spark
- ericmark
- Been thanked: 783 times
My consumer unit had type AC RCBO's and a SPD, but now need to be type A so will cost more, and it cost me in 2019 about £350, it took my son all day to fit it for me, in fact longer as I had to complete the job, and we took a chance and only tested once completed, should have done a full EICR before starting.
So £1000 could be a fair price, where the problem arises is when some one runs off when it goes wrong, had it with parents house, it took more time and money to correct than if I had done job from start.
So norm is three quotes, if one is way cheaper or dearer to others as why, it may be one is using expensive manufacturer, had I used Wylex instead of fusebox the price could have doubled. Using RCBO with spark detectors even higher.
