Stanley Fatmax Wire Stripper
man100
Has thanked: 6 times
Post by man100 »
I have recently purchased this and there seems to be an adjustment screw on the top left flex cutter block that is not referred to on the instructions or any YouTube upload on the product.
It is marked + and - what's it for does anyone know ?
Has thanked: 47 times
Been thanked: 2559 times
Why not try it max one way, then max the other way.
etaf
Has thanked: 37 times
Been thanked: 146 times
Post by etaf »
i purchased a set from toolstation a few years ago - and the adjustment was for thickness of wire
does this help
https://www.youtube.com/watch?v=GJQio2EqkOs&t=48s
or is this NOT what you are adjusting
these are the set i purchased
https://www.youtube.com/watch?v=6OjwwIH1czY&t=58s
adjustment around 54seconds
Simple DIYer
Wayne
aeromech3
Has thanked: 177 times
Been thanked: 665 times
Post by aeromech3 »
It adjusts the clamping force of the left hand cable grip. Depending on the cable diameter, if set too far negative, the cable will slip instead of being gripped firmly for stripping.
man100
Post by man100 »
Thanks that's it for tension adjustment I must be getting slow in my old age thanks to all
Return to “Tool Talk”
