- It is currently Thu Apr 03, 2025 8:21 pm
New electric hob installation
- Has thanked: 32 times
- Been thanked: 816 times
i should add to my post last night for clarity... i was thinking more about gas hobs and laminate upstands running behind them which is not a good idea.
fin
- Has thanked: 11 times
- Been thanked: 2 times
Post by dazzyboy10 »
So does that mean I should be pretty safe in installing it within the 150mm suggested by the manual or will I have to stick with it? If I have to stick to the 150mm, the hob will be a third across the cutlery drawer and under the cabinet.
dazzyboy10
- Has thanked: 740 times
- Been thanked: 2355 times
40mm is probably the air clearance each side off the oven body so below worktop leveldazzyboy10 wrote: ↑Fri Jan 06, 2023 3:00 pmI get that more space is practical but we don't have that luxury, plus, the link you sent me for AO.com, does state a minimum of 40mm for space on the sides!
Here's what I foundbig-all wrote: ↑Fri Jan 06, 2023 10:48 pm40mm is probably the air clearance each side off the oven body so below worktop leveldazzyboy10 wrote: ↑Fri Jan 06, 2023 3:00 pmI get that more space is practical but we don't have that luxury, plus, the link you sent me for AO.com, does state a minimum of 40mm for space on the sides!![]()
- Screenshot_20230106_220228_Chrome.jpg (126.22 KiB) Viewed 1682 times
dazzyboy10
as it specifically says hob then its on top clearences
Neelix
- Argyll
- Has thanked: 1192 times
- Been thanked: 583 times
If you're still concerned about heat can't you use a bit of fire retardant MDF attached to the side of the cabinet obviously painted and used as a heat shield?
I'm having difficulty trying to picture this. Maybe best attaching a photo.
Argyll
Neelix
Well I've just been told by the electrician who's going to install it that the 150mm is minimum requirements and that 300mm is rule of thumb. Looks like I'm gonna either have to get rid of the larder and replace with new units or raise the height of the cabinet which is only 46cm above the worktop. To have the hob not placed under the cabinet, would require only 90mm of clearance from the larder.
dazzyboy10
- Has thanked: 118 times
- Been thanked: 219 times
You should confirm with said electrician which regulations he is using and see what they say
Neelix
He stated that it's the rules they have to abide to when it comes to contracts and isn't sure what regs, could be building regs
dazzyboy10
The only other options I have if I need this 150mm clearance is to get a shorter wall cabinet (current is 800mm), about 700mm and as the hob will be sitting inside our cutlery drawer in a 600mm cabinet, is to maybe create 2 drawers, side by side at 300mm each and make the right side drawer a false one. It's only for cutlery anyway. Or, I could stretch to an 800mm cabinet that the hob sits inside and a separate 400mm cabinet for the cutlery drawer and cupboard space underneath
dazzyboy10
Sounds like BS to me.dazzyboy10 wrote: ↑Sat Jan 07, 2023 1:43 pmHe stated that it's the rules they have to abide to when it comes to contracts and isn't sure what regs, could be building regs
Ask him again which regs he is reading
Neelix
- Has thanked: 1415 times
- Been thanked: 4031 times
dazzyboy10 wrote: ↑Thu Jan 05, 2023 9:04 pm The installation manual that came with our hob, states that there needs to be at least 150mm clearance on the sides from walls or cabinets
I'm sure that Manufacturers instructions would have to be followed in this case regardless of any additional regulatory requirements.
Ok well its clear I'm gonna have to stick to manufacturers guidelines as I spoke to technical support at Hoover and they've said it has to be adhered to. As of that, I will need to make a number of changes. The main issue I'm seeing is that I will be needing to cut into the cutlery drawer by about 3 inches. That being said, will there be any issues in doing this, especially heat wise?
dazzyboy10
