Changing Danfoss 2 port Valve to Honeywell
Argonaut
Has thanked: 6 times
Post by Argonaut »
I have a Danfoss 2-port valve model HPA2 (which has suspect motor issue)
I can get Honeywell 2-port valves & motors much cheaper & easier as local Trade place stocks Honeywell.
Is there a direct equivalent Honeywell motor activator? ....... so I could just swap the synchronous motor over ? or would I need to swap the whole valve ?
Trade counter said there is also a generic synchronous motor that fits either ? .... they any good ?
Ideally, I would obtain a complete Honeywell valve now, but just swap over the motor now ..... and change valve later when the system can be drained down.
Has thanked: 47 times
Been thanked: 2597 times
Argonaut wrote: Fri Mar 03, 2023 10:30 amTrade counter said there is also a generic synchronous motor that fits either ? .... they any good ?
Would that not depend on the build quality of said generic motor? I thought the whole idea of something being generic was that I (for example) can make one, and my neighbour (example) can make one too, neither being original, but both being generic.
I guess it is down to how much you want to spend, ideally you should change the whole valve, but as you said, you would need to drain it down.
OnlineOnline
Argonaut
Post by Argonaut »
OK ignore the comment on Generic …. Is the Honeywell & Danfoss motor a direct swap ?
aeromech3
Has thanked: 177 times
Been thanked: 665 times
Post by aeromech3 »
It is a 3/4" valve body and a Honeywell will not fit. Might be any synchro valve motor will work, differences usually wire end fittings, wattage, cog material and RPM but from heatingcontrolsonline.co.uk you can get the actuator for a reasonable price
Argonaut
Post by Argonaut »
OK ... if Honeywell motor won't fit, I I'll swap the whole thing out, been told Danfoss are trouble so no point changing it for another one.
aeromech3
Post by aeromech3 »
Mmm, the Honeywell 'actuator' will not fit on the Danfoss valve body, the generic or Honeywell synchro might fit the actuator.
Swap the whole thing! likely the new valve you choose will be compression 22mm fit so check your pipe plumbing to see if it is 3/4" with BSP thread, a compression is easily ident by the way the nut faces per picture.
Have had plenty of Honeywell failures in service, mate of mine had a plumber fit a complete new valve, but had same trouble and did not realise the new one was faulty until he had changed other components and spent half a day doing so. I'd take a look under the Danfoss cover at the access and connectors and compare to a synchro available in the market place, but that is miser me.
Argonaut
Post by Argonaut »
It’s a 28mm compression fitting for sure
Neelix
Has thanked: 118 times
Been thanked: 217 times
Post by Neelix »
All motorised valves are trouble …..
Razor
Has thanked: 483 times
Been thanked: 1251 times
Post by Razor »
Just change the sychron. About a tenner and will last as long as a new one would.
New motor and a couple of wago connectors and it's done - some come with new crimps or spin ons but wagos are great for it!
Argonaut
Post by Argonaut »
I have a new motor head coming today...hope the switch works the same.
