cleaning paint rollers
Hi all for my design technology NEA i have to find a solution to a problem. My uncle is a painter and decorator and he says cleaning paint rollers is a nightmare. He says that even if you scrape off the paint you have to wait for the residue to dry before switching colours. When using a new roller the fluff all sticks to the wall until it is worn in. Therefore, I was thinking about creating a roller cleaner with jets to spray the roller clean while spinning to avoid water build up which would attach to a hose pipe. If you could give me your opinions on this. Thankyou
- Tom d'Angler
- Has thanked: 1142 times
- Been thanked: 553 times
Hi Georgia. I'm afraid you would be reinventing the wheel as there is already a contraption that easily cleans rollers and brushes - https://roamwildproducts.co.uk/products ... er-cleaner.
- Has thanked: 825 times
- Been thanked: 3574 times
Bung them in the bin. Cheap enough if you keep them live for the job in cling film.
- arco_iris
- Has thanked: 184 times
- Been thanked: 535 times
I roll them back'n'for in the kitchen sink under running water until it runs nearly clear. Then spin them out against a brick wall. Then stick the handle on a broom handle, lean it up against the gate, and spray with a nozzle on a hose pipe (standing well back, of course). Nearly dry by now, put away for next time.
- Has thanked: 47 times
- Been thanked: 2591 times
as Tom d'Angler says, the thing you are thinking of has been out for years, I remember watching on QVC many years ago, any way, here is a variant of it.
Inept people use the QUOTE BUTTON instead of the QUICK REPLY section![Smile :-)](./images/smilies/icon_smile.gif)
![Mr. Green :mrgreen:](./images/smilies/icon_mrgreen.gif)
![idea1 :idea1:](./images/smilies/idea1.gif)
- Argyll
- Has thanked: 1188 times
- Been thanked: 583 times
Yep a painter told me the same thing. I bought mine a good few years ago although mine is yellow. Great thing.Tom d'Angler wrote: ↑Mon Apr 03, 2023 5:59 pm Hi Georgia. I'm afraid you would be reinventing the wheel as there is already a contraption that easily cleans rollers and brushes - <span class="skimlinks-unlinked">https: ... ner</span>.
- dynamod
- Elephant Man
- Has thanked: 592 times
- Been thanked: 1444 times
So many gadgets are often solutions to problems that never really existed in the first place IMHO.
That said, it doesn't stop some of these things selling, and if you can sell something that competes with existing products, without infringement of any copyright matters, then good on you.
It's not something the trade would necessarily use, but the public love all that QVC stuff.
Nihil expectore in omnibus
- Tom d'Angler
I'm on my third one now. The first two were yellow and my latest one is red. Each one lasts me about a year. Mind you, I only use it for brushes as I bin rollers after each use (apart from the white ceiling one which I keep in a tie-handle bag) as they're relatively heap.
Someone will invent a condom washer next
![Laughing :lol:](./images/smilies/icon_lol.gif)
- Tom d'Angler (Wed Apr 05, 2023 4:07 pm)
- Has thanked: 201 times
- Been thanked: 513 times
I tend to scrape and rinse then soak rollers in a bucket of soapy water which seems to release any residue , run under the tap and all done. I will also clean the small rollers too . Probably not worth it some will say but a previously used small roller is fine for spreading glue or for using with things like fence paint.
Many a word and all that dwd..
https://m.youtube.com/watch?v=2jOSmhRJY4o
I also seem to recall from history that condoms were originally made of animal gut and were washed and reused.
Good point G
Washing rollers I suppose depends on whether you are constantly using your rollers. The average Joe only uses rollers on one job with a period in between. When I washed rollers in the past they tended to dry with a hard pile and were not great on second use. As rollers became cheap I bought and dumped them as I went. The mini rollers have largely replaced brushes for me as they get paint coats on quickly and evenly, something that water based trim paints require I find. These are always dumped. I do keep rollers alive for the job duration by wrapping cling film around them to stop drying out and this works well. If you are a pro dec then this might not be a system for you but it suits me.
