scrap
This forum is for topics or posts that do not fit into any other forum, this includes online games such as word Association etc.
fin
Has thanked: 32 times
Been thanked: 807 times
scrap
Post by fin »
ive ended up with a couple of rubble sacks wotth of scrap cable all bunched up standard sort of stuff.
normally i just weigh it in alongside my other scrap. normally seperate out brass and copper.
is it worth while stripping the cable or not\? what do you lot do?
is it something which makes basically pennies difference unless you have a decent amount of it weight wise? and then labour alone makes it pointless?
arco_iris
Has thanked: 184 times
Been thanked: 535 times
scrap
Post by arco_iris »
I don't recall the difference in rates, I took in a bucket each of copper, lead, brass and a box of cable, £100.
You could sit and strip one sack, not the other, see how long it takes & difference in value.
Put it on a bonfire (outside, it stinks!), fish it out next day; there are vids on utube of homemade bulk cable stippers.involving knife blades.
Edit, found the ticket.
Copper plumbing bits 7kg £38 so that's £5.40 per kilo;
Cable 3kg £5 so £1.66/kg.
also got £3/kg for brass & £1.10/kg for lead.
oz0707
Has thanked: 166 times
Been thanked: 68 times
scrap
Post by oz0707 »
I spoke to a sparky the other month who strips his but im not sure of the difference in prices between the two. Ring up the merchants and ask. Id prob just weigh in as it is.
Razor
Has thanked: 483 times
Been thanked: 1251 times
scrap
Post by Razor »
There's a massive difference between stripped and insulated wire. Several thousand per ton!
https://www.letsrecycle.com/prices/meta ... ices-2023/
These users thanked the author Razor for the post:
APDIY (Fri Apr 07, 2023 10:03 am)
Neelix
Has thanked: 118 times
Been thanked: 215 times
scrap
Post by Neelix »
For 2 bags…..
Don’t bother stripping it. Takes too long and life is too short
Has thanked: 823 times
Been thanked: 3560 times
scrap
I think that the price is weight adjusted to allow for the insulation at the yards.
Grendel
Has thanked: 201 times
Been thanked: 509 times
scrap
Post by Grendel »
I took some scrap in today . The bright copper ie the stripped stuff was around three times the price of household with the insulation left on. £6400 a tonne verses £2100 . No 2 was a little lower than bright. That's stuff that's been burnt off or is tinned. Mind despite the price I didn't see a penny of the grand and a bit as it all ends up in mrsG's bank account...
bourbon
Has thanked: 11 times
Been thanked: 18 times
scrap
Post by bourbon »
Price has gone up a bit then?
Grendel
scrap
Post by Grendel »
Decent enough ...
oz0707
scrap
Post by oz0707 »
One thing I've always been told never weigh in before xmas. It worked this year prices were higher in feb than December
Grendel
scrap
Post by Grendel »
I've been taking scrap in for decades now following in my father's footsteps and sometimes I thought I was being spied on and the price dropped just before I took a van load in when I was told at the scrapyard " pity you weren't here last week .... "
Return to “The Lounge”
