Sealing MFC for bathroom
Doc M
Has thanked: 20 times
Been thanked: 2 times
Post by Doc M »
Hi All!
I bought an MFC textured woodgrain vanity unit: https://www.heatandplumb.com/acatalog/n ... t-arn2505d
Our bathroom has high humidity and no extractor.
I doubt very much that this vanity will make it through the winter without sealing - I have no idea what to seal it with. Also, I will be buying a dehumidifier to offset the lack of extractor fan.
I have leftover Zinsser Perma-White satin (that I used on the bathroom ceiling) that I could use on the exposed chipboard (see picture), but I was hoping that I could use some kind of clear varnish or sealer on the woodgrain effect melamine to help protect further against moisture/humidity and prevent the vanity from blowing/warping/deforming. Help! :dunno:
moderator2
UHM Super Moderator
Has thanked: 155 times
Been thanked: 569 times
Post by moderator2 »
Doc M, Just one thread per topic please. I've deleted the duplicate in Carpentry.
These users thanked the author moderator2 for the post:
Doc M (Fri Jun 23, 2023 1:47 pm)
Has thanked: 823 times
Been thanked: 3560 times
I would use a varnish on exposed edges, as long as they are sealed it will be fine. Melamine is impervious to water in the main it is the moisture that creeps into exposed edges that casues a panel to blow. It would be an idea to explore the excess humidity issues and find a remedy.
Doc M (Fri Jun 23, 2023 3:59 pm)
Doc M
Post by Doc M »
Thanks dewaltdisney - I'll make sure to varnish the exposed chipboard with no malamine strips. I'll look into an extractor or dehumidifier! :-)
