makita model 5077B 7 1/4" Hypoid Saw
Deansum
Post by Deansum »
So the saw just stopped. I checked voltage from the wall outlet, saw power cord. switch. The wires or coils do not look burned. I cleaned off the armature which wasn't that dirty. The brushes seemed okay although I don't know how to check them. The blade and gears turn freely. Any help would be appreciated.
etaf
Has thanked: 37 times
Been thanked: 146 times
Post by etaf »
how old and how much use ?
i have seen a few cases where the brushes look OK and replacing them fixes the issue both on festol models track saws
see peter millard and robin clevett youtube videos, both surprised brushes was the fix
if you can get cheap replacement brushes maybe worth trying
Simple DIYer
Wayne
Has thanked: 47 times
Been thanked: 2556 times
How did you do the following?
Deansum wrote: Sun Aug 06, 2023 7:02 pmI checked voltage from the wall outlet
just wondering, are you in America?
Deansum
Post by Deansum »
Thanks for the replies!
Yes I am in the U.S. I was using the KISS method. So I wanted to make sure the first step was the outlet.
I will try new brushes. That would be simple enough.
Deansum
Post by Deansum »
Well, new brushes didn't work.
Has thanked: 807 times
Been thanked: 3496 times
Deansum
Post by Deansum »
I have a voltage meter. I guess what I would need is what readings I should get from component to component like where on the switch do you take a reading to see if is working.
Deansum
Post by Deansum »
I fixed it! Inside the handle there was a wire, the black one, that registered with continuity using a volt meter. But when I moved the wire it came or was broken. I replaced that wire and wala! it worked.
These users thanked the author Deansum for the post:
dewaltdisney (Wed Aug 23, 2023 3:57 pm)
Well done, a better result than I had :lol:
Deansum
Post by Deansum »
Do I need to click on something to show the post is done?
moderator2
UHM Super Moderator
Has thanked: 154 times
Been thanked: 566 times
Post by moderator2 »
Deansum wrote: Fri Aug 25, 2023 2:44 pm Do I need to click on something to show the post is done?
No.
Return to “Tool Talk”
