Hi
Looking to shelve a cupboard ( built in wardrobe)
It’s empty and recently built within a converted garage.
Looking to fit several shelf and possible a rail
My plan was to fit batons to the studs to hold the shelves but they are pretty long 1.8m. 16mm Conti board being used for the shelf
My concern is they will sag in the middle
Any advice?
Cupboard Shelving
- Has thanked: 818 times
- Been thanked: 3514 times
Cupboard Shelving
Yes, they will sag, they will sag leaning against a wall. You can screw underneath verticle crossrails on edge that wiĺl help but much will depend on loading. Screw through from the face or use joint blocks at a push.
