Power Source/Portable Turntable
Onar
Has thanked: 16 times
Been thanked: 2 times
Post by Onar »
Hello guys,
I have a Portable Turntabler but have lost the power source.
Can anyone please advise on a suitable one ?.
It is Maplin Prosound Turntable.
Takes 5V DC
I checked with Maplin but they cannot help.
Please see photos.
Thank you.
ericmark
Has thanked: 117 times
Been thanked: 783 times
Post by ericmark »
It is 5 volt DC and 1 amp so well within most USB power supplies, also standard coax power plug and +/- clearly marked, can't really see a problem. Using tablet so not easy to hunt for you, but should be easy enough.
Has thanked: 47 times
Been thanked: 2579 times
As said, what is your problem? 5v power supplies are available in the usual places. Just don't get one that has multi voltage (a lot of them out there too) Just depends how much you want to spend, I bet temu have them too.
aeromech3
Has thanked: 177 times
Been thanked: 665 times
Post by aeromech3 »
Do get the polarity correct. Positive inner, negative outer.
aeromech3
Post by aeromech3 »
An example from amazon, do zoom on plug picture to check polarity:
Aclorol 5V 2A Power Supply
Onar
Post by Onar »
Thank you.
I will check.
Return to “Electric Forum UK”
