Plasterboard over artex
Beav
Has thanked: 52 times
Been thanked: 3 times
Post by Beav »
Hi there,
What sort of cost should I expect to plasterboard and plaster over a small artex bathroom ceiling? (Developed a few cracks) The one side does slope down slightly as well. I would say the bathroom is only really 3m x 2m
Has thanked: 831 times
Been thanked: 3627 times
I would fill the cracks and paint over, don't cause unnecessary headaches. I used decorator caulk in a similar situation, I rubbed it in and painted over as it takes paint well.
Beav
Post by Beav »
dewaltdisney wrote: Fri Oct 20, 2023 3:27 pm I would fill the cracks and paint over, don't cause unnecessary headaches. I used decorator caulk in a similar situation, I rubbed it in and painted over as it takes paint well.
That's an option. As it's artex it contains asbestos I think? The ceiling seems to have formed a bubble so not sure if more cracks will appear as well.
Wasn't sure how clean it would look filling it as its artex. The aim is its going to be a rental so thought may as well take the time to do it properly whilst no tenants are in.
From photos a local plasterer said it would be upto £450 max.
Neelix
Has thanked: 118 times
Been thanked: 219 times
Post by Neelix »
Over board and plaster if you want a decent finish
Beav
Post by Beav »
Neelix wrote: Fri Oct 20, 2023 9:48 pm Over board and plaster if you want a decent finish
That's what I'm thinking then it's done. Presume £450 ish sounds about right?
Neelix
Post by Neelix »
Beav wrote: Sun Oct 22, 2023 7:52 pm That's what I'm thinking then it's done. Presume £450 ish sounds about right?
Best get a few quotes and your location in the UK matters with pricing
Return to “Plastering Forum”
