Hello folks - searched for an answer, but no joy
I’ve got a chimney that leaked (but this is now resolved)
After it was fixed, I coated with “Thompsons Stain Block Damp Seal” —> https://www.amazon.co.uk/TDS250-250ml-T ... 001GU4BEE/
I now need to dot and dab, but I’m not 100% sure if I can / should PVA first (how will it interact with Stain Block? Will it adhere?)
Very new to this. Any advice welcome.
Picture attached in case it helps.
PVA on top of Stain Block / Damp Seal
- Has thanked: 9 times
- Has thanked: 818 times
- Been thanked: 3514 times
PVA is the last thing in a damp situation as it is water based and reactivates when wet. It looks like you are dry lining plasterboard onto studs so I really do not see any need for further wall sealants as long as it is dry. I may have read this wrong?
- and_the_noobie (Sat Oct 28, 2023 7:09 pm)
- aeromech3
- Has thanked: 177 times
- Been thanked: 665 times
As DWD.
Well if it states you can paint and paper over so dot and dab should adhere, would avoid PVA, it is more of a sealer.
- These users thanked the author aeromech3 for the post:
thanks - yes, the issue was fixed last year, so I can confirm that the wall is definitely not getting wet now - though I did the seal as a precaution as there were still some low damp readings on it from where it hadn't fully dried outdewaltdisney wrote: ↑Sat Oct 28, 2023 11:50 am PVA is the last thing in a damp situation as it is water based and reactivates when wet. It looks like you are dry lining plasterboard onto studs so I really do not see any need for further wall sealants as long as it is dry. I may have read this wrong?
I've not done plasterboard before but had read from this about using PVA to ensure the wall doesn't take damp from my adhesive: https://www.buyinsulationonline.co.uk/b ... lete-guide
my thought was that the damp seal / stain block is already doing that, so was trying to figure out if I can skip the PVA step, or if I should still do it :)
thanks to you and @aeromech3 for confirming PVA isn't necessary :)
would you know if the above website is correct in stating that PVA should be used on other (non damp seal stain blocked) walls before dot and dab? :)
- Has thanked: 1414 times
- Been thanked: 4019 times
and_the_noobie, A mix of PVA and water is usually used when applying a finish coat of plaster to control suction and stop the plaster drying too quickly. I've never heard of PVA being used for dot n dab.
- These users thanked the author wine~o for the post:
thanks - sounds like I'd best go off and look at a few more guides / "how-to's" :)
