I am not quite sure where to post this, so I hope I'm in the right place! I have a problem which has been impacting my health. Over the past few years, there has been a strange musty smell in my bedroom which has been triggering my allergies and making me feel rather unwell. I have been able to live with this, perhaps unwisely so - however, recently, it has worsened, and my health with it. Now, I am determined to get to the source of this. The smell "seems" to have reemerged with the recent changes in the season, although please note the smell comes and goes as it chooses. However, for example I have noticed that if I open the window to air the bedroom, the smell arises once again. I have always supected mold and/dust. Yesterday, I started to lift the floorboards. I will continue to do so, however, for now I would very much appreciate any advice you have regarding what the problem could be and how I go about tackling it?
Our house is a two-storey terraced, perhaps 1930s. The problem area is the first floor bedroom. I have started in one section of the bedroom, to the left hand side of the chimney stack (as one faces it). FYI, the chimney is not currently in use, and it has not been used for at least 5 years. However, I do find it strange that the joists are so dark in colour - I wonder how could this be and does it matter? You can see that this section's general colour is quite dark - the dirt or dust is really dark, and the smell is musty. The joists here are noticeably darker in hue than the other joists farther away from the chimney - these joists farther into the room are more brown in colour. In the immediate corner right at the chimney stack (i.e., where the bedroom wall meets the chimney stack) there is a deep hole which extends down into the lower sections of the chimney - this is filled with dark dirt and dust, and I cannot quite see where this hole ends. Here is a closeup of a section of the darkened joists and the ceiling covered in old bits and pieces. There is a firm but brittle material stuck onto the ceiling wood latts, some of which is loose - this too has become quite discoloured. Moving forward:
- I intend to remove all the flooring and try to clean up the loose dirt, dust, and rubble. Perhaps getting some powerful vacuum would help with this? I am wondering should I remove the aforementioned "brittle material stuck onto the ceiling wood latts"?
- I am keeping in mind that there may be a mold issue - however, I suspect the problem is more to do with rising and circulating dust...?
- When I have cleaned out the loose dirt etc. should I use some form of sealant to keep any remaining dust and/or smells in place? Because of my allergies, I need to stay clear of potent chemicals, for example.
- Perhaps, I could seal the gaps between the floorboards after I have relayed them? Would this keep any smells at bay?
