Which is the quicker way to dry the plastering?
- Has thanked: 166 times
- Been thanked: 3 times
My kitchen was plastered earlier this week and I was told that plaster dries quicker in hot weather than in cold.
As it's cold at the moment (unfortunately), I have two options, leave the windows open or keep them closed.
Which will dry the plastering quicker in the cold weather?
- Has thanked: 823 times
- Been thanked: 3560 times
Let it dry slowly otherwise it will crack or craze.
- Dxc712 (Fri Nov 10, 2023 10:14 pm)
- Has thanked: 118 times
- Been thanked: 215 times
Ventilation is the key. Excessive heat is a huge mistake
It is drying slowly. The heating is off in my flat (as it always is).dewaltdisney wrote: ↑Fri Nov 10, 2023 9:41 pm Let it dry slowly otherwise it will crack or craze.
Should I have the windows open or closed?
Do you think I should have the windows open in this weather?
Maybe just a crack to let the moisture out. As you have no heating on the fabric of the structure will be cold and opening the windows will not hasten drying and the moisture released will condense on the coldest surfaces.
- Dxc712 (Fri Nov 10, 2023 10:33 pm)
Thank you :)dewaltdisney wrote: ↑Fri Nov 10, 2023 10:30 pm Maybe just a crack to let the moisture out. As you have no heating on the fabric of the structure will be cold and opening the windows will not hasten drying and the moisture released will condense on the coldest surfaces.
Yes. Plaster contains a large amount of water - it needs to escape the room
Thanks. I wasn't sure if opening the windows and making the room colder would slow down the drying of the plaster.
- Has thanked: 736 times
- Been thanked: 2341 times
would a dehumidifier not both give gentle heat and remove moisture aiding drying ??
I ran the water in the kitchen just now and a few drops went on the plaster.
Is this a problem or am I worrying unnecessarily?
I've attached a photo.
- Droplets.jpg (177.72 KiB) Viewed 4385 times
- Has thanked: 250 times
- Been thanked: 212 times
It's perfectly fine
Preempting a potential disaster will be to know how to paint this new plaster. You will need to do a mist coat, an ordinary emulsion watered down to 4:1 paint/water mix. This will sink in and provide a good key for the finishing full-strength coats.
- Dxc712 (Sat Nov 11, 2023 9:30 am)
Thanks.dewaltdisney wrote: ↑Sat Nov 11, 2023 9:18 am Preempting a potential disaster will be to know how to paint this new plaster. You will need to do a mist coat, an ordinary emulsion watered down to 4:1 paint/water mix. This will sink in and provide a good key for the finishing full-strength coats.
What's the potential disaster that could happen?
