Which is the quicker way to dry the plastering?
- Has thanked: 807 times
- Been thanked: 3498 times
You may have gone straight on with emulsion which would have caused delamination of the paint. It is a common error.
- Dxc712 (Sun Nov 12, 2023 1:51 pm)
- Has thanked: 151 times
- Been thanked: 2 times
I haven't done that, thankfully. I'm still letting it dry before it's tiled on Thursday.dewaltdisney wrote: ↑Sat Nov 11, 2023 10:00 am You may have gone straight on with emulsion which would have caused delamination of the paint. It is a common error.
I noticed a mark in the plastering today that I didn't spot before. It's right on the edge of where the tiles will stop.
I've put a toilet roll next to it to give an idea of size.
Is this something that the tiler can address?
- 20231112_134536.jpg (67.15 KiB) Viewed 1789 times
- 20231112_134527.jpg (93.22 KiB) Viewed 1789 times
When the tiling is done, put your mist coat on the walls, fill any surface defects with filler, and paint over with your finish coats.
- Dxc712 (Sun Nov 12, 2023 2:50 pm)
Thanks. So you don't think what you saw in the photo would be a problem for the tiler?dewaltdisney wrote: ↑Sun Nov 12, 2023 2:29 pm When the tiling is done, put your mist coat on the walls, fill any surface defects with filler, and paint over with your finish coats.
No, his edge bead may cover some of it possibly, just assess it after he had done and follow my previous post.
- Dxc712 (Sun Nov 12, 2023 5:38 pm)
Thanks. Will do.Dxc712 wrote: ↑Sun Nov 12, 2023 2:50 pmThanks. So you don't think what you saw in the photo would be a problem for the tiler?dewaltdisney wrote: ↑Sun Nov 12, 2023 2:29 pm When the tiling is done, put your mist coat on the walls, fill any surface defects with filler, and paint over with your finish coats.
- Has thanked: 249 times
- Been thanked: 212 times
All your paint could peel if you don't most coat
