Makita XGT 40V Tracksaw not bevelling to 45 degrees
Whizkido
Has thanked: 1 time
Post by Whizkido »
Hi all,
I just picked up a Makita XGT 40v tracksaw (SP001G) and I'm having some issues with the bevel indicator marker.
When the track saw is supposedly tilted to 45 degrees, the orange marker indicates that its 1 degree short of 45 degrees, maxing out at 44 degrees. When flat, the indicator sits flat at 0 degrees.
Also, the track saw allows up to 48 degrees bevel but the market sits between 47 and 48 degrees.
Has anyone seen this before? One of the condition of the return is that the item is supposed to be unused hence not making cuts.
Photo 27-11-2023, 11 06 09.jpg (248.24 KiB) Viewed 1534 times
Photo 27-11-2023, 11 05 55.jpg (205.28 KiB) Viewed 1534 times
Has thanked: 831 times
Been thanked: 3628 times
Have you measured the actual angle between track and blade? I never put too much reliance on the angle gauges as my saws are all out where they have been banged over the years. If you have not got an angle then fold a piece of square paper corner to corner.
OnlineOnline
Has thanked: 740 times
Been thanked: 2355 times
the saw looks fully adjustable
the normal is ----=try the saw as marked
check the work with an accurate device like combination square or rotate the offcut to give a corner
adjust actual cut till accurate then move indicator then recheck with a cut
aaannnddd up to 48 degrees although in this context it should perhaps mean 48+/-0.5 degrees' the general meanging off up to means the maximum we expect is 48 but could be less like up to 48% cheaper tickets
Whizkido (Mon Nov 27, 2023 2:07 pm)
OnlineOnline
Return to “Tool Talk”
