Wooden stairs that creaks badly .
We have a shared wooden stair leading from ground floor to our apartment 2nd floor entrance hall and door .
Built in the 60's , used to be carpeted but then ripped up by landlord as considered unsafe .
Creaks and echos now very time someone walks up or down it . What's can be done apart from wood oil put on it ? Any structural ideas . I thought of some thin wooden props put under the the worse sounding steps at intervals but will have to be secured properly and abit unsightly really but I don't have any more ideas .
Any tips suggestions welcome .
Can't post an image , won't allow external links .
- Has thanked: 47 times
- Been thanked: 2564 times
Yes it does.
I would guess the picture size is too big, see my signature for info of how to post pictures.
- Has thanked: 735 times
- Been thanked: 2336 times
theres a fair chance they bolstered the carpet in the joint at the back off each tread weakening the stairs
for the moment, do not try any oil
is there a gap at all at the back off the treads ??
can you get under the stairs and look at the tread and wedges??
There are No gaps to even get a nail into . My thought too would be to see the underneath for a thorough assesment , just that it's covered with plaster board and I'm not responsible for it .
I didn't want a big job but probably the only way to assess as nothing is obvious on the face .
can you get a screwdriver in at all between the back off the step and the riser??
- Has thanked: 810 times
- Been thanked: 3500 times
The staircase would have been made from two stringers that would have deep routered housings for the treads and risers. These would have been glued up and cramped until dry. Older staircases had wedged joints to keep them tight. In your case I suspect the glue has become loose on some treads causing the creak. Working under these treads can be identified and beefed up with mechanical fixings. You could try squirting some PVA glue in the tread gaps which may help. These options may not be open to you and I feel your only recourse is to the landlord.
I think I've scratched my head enough on this one ,
Just like to fix some things . I'll Go back to my den with and my glue gun .
This needs a large restoration effort , not my speciality AT ALL .
that gap can only be because off wedge problem [most likely cause ] or possible [very unlikely ] softening or decay off timbers
