Need a key for this lock
flembot
Has thanked: 16 times
Post by flembot »
Hi guys, this metal door is attached to the gable wall of our home (we own the house).
Think this door houses a flow and return pipes for an old communal heating system that used to be used in these properties. We are considering bricking this up. But need to first get the door opened!
Anyone know what this type of lock is? Anyone know where I could buy a key to fit this lock?
Thanks in advance!
Bob225
Has thanked: 98 times
Been thanked: 872 times
Post by Bob225 »
Looks like a half moon service key, a flat blade should do the trick, if not undo the gutter bolts, push on the lock to stop the nuts spinning
flembot
Post by flembot »
Bob225 wrote: Tue May 07, 2024 2:20 pm Looks like a half moon service key, a flat blade should do the trick, if not undo the gutter bolts, push on the lock to stop the nuts spinning
Seems like I can turn it with a flat blade, but nothing seems to unlock or come free.
If I were to undo the gutter bolts and removed the lock, would the door spring open or something?
Whatever I do with this I need to be able to close it again as this is a public facing wall right onto a walkway. Essentially I want to be able to secure it again.
Bob225
Post by Bob225 »
You should be able to do it, it's poss a fire brigade key (FB drop) key
Bob225
Post by Bob225 »
what is the name on the lock ends in OY or DY
edit. it maybe Abloy
Edit 2. Yes its an Abloy cut key
https://www.barnsleylock.co.uk/abloy-cl ... 4001-p.asp
Bob225
Post by Bob225 »
Return to “General DIY forum”
