Filling hole in ceiling
spr0ut
Has thanked: 2 times
Post by spr0ut »
I am decorating my daughter's room this weekend and have removed a fuse spur which was fed from a cable in the loft. There is now a small hole (about 1"x1") in the ceiling which I want to fill. I tried with polyfilla but it's not working as there's nothing for it to bond too and it's too heavy so drops down.
Any recommendations for something to fill the small hole with so I can paint on top?
toolbox
Has thanked: 128 times
Been thanked: 210 times
Post by toolbox »
Cut a bit of wood a little narrower than the hole but longer drill a couple of small holes in it to allow a thread or fine string to go through and back.
push the wood up and slide across to rest either side , hold with the string and fill. you can either pull the string out and patch when the filler has partly gone off or wait till it drys and pull the string through then.
I would let it dry if the string will not come out cut it just under flush and make good.
etaf
Has thanked: 38 times
Been thanked: 151 times
Post by etaf »
i have used a bit of car body grille mesh to do that before
if in UK , Halfords
https://www.halfords.com/motoring/paint ... 11606.html
Simple DIYer
Wayne
Duck_Tape
Has thanked: 151 times
Been thanked: 45 times
Post by Duck_Tape »
Absolutely the best filler for this is "One Strike"
Code: Select all
https://www.toolstation.com/everbuild-one-strike-ready-mixed-filler/p20822
it is super light, so it does not fall out of a vertical hole.
When you buy it, you would think the pot is empty it's that light.
I use this all the time now.
I love hard work, I could watch it all day
Ktuludays
Has thanked: 250 times
Been thanked: 212 times
Post by Ktuludays »
Lightweight deep crack filler
Return to “General DIY forum”
