Boxes near window - are they safe to remove?
ALK
Post by ALK »
Hi everyone.
I've just moved into a new house and near some of the windows are these boxes. I'd like to remove them, but wanted some opinions on whether it would be safe to do so, and/or what the purpose of the boxes might be.
Does anybody have any thoughts?
Box 1 - slightly bigger than a matchbox and has a wire that seems to be going outside:
Box 2 - standard phone socket size, no obvious wires, but presumably some going into the wall:
Appreciate any thoughts on whether they're okay to remove and something I can do myself.
Has thanked: 47 times
Been thanked: 2590 times
Box 1 is a standard junction box used by telecoms companies (The cable probably goes to a telegraph pole)
Box 2 is where you (used to) plug a telephone into. (Look at the box adjacent, it clearly says NTL, they were a cable company, now taken over by virgin media)
aeromech3
Has thanked: 177 times
Been thanked: 665 times
Post by aeromech3 »
Box 1, I have a few of them around rooms in my house, the previous owner had them as standard telephone extensions; slightly bigger than a matchbox (excluding extra long matches)not sure if they could be master socket from the telephone Co as S-E seems to suggest.
Either way they would be low voltage about 50vdc.
stevei
Has thanked: 87 times
Been thanked: 123 times
Post by stevei »
It is safe to remove them but whether you should or not depends on what telecoms you have.
Return to “General DIY forum”
