Skirting Cover
yartin
Has thanked: 144 times
Been thanked: 126 times
Skirting Cover
Post by yartin »
Hi
Is it worth using skirting cover over old style ones? Any disadvantages?
Pic of skirting cover attached.
skirting cover.gif (77.51 KiB) Viewed 454 times
Rorschach
Has thanked: 108 times
Been thanked: 1038 times
Skirting Cover
Post by Rorschach »
There' be so many lumps and bumps on the old skirting I doubt you will get a tight fit without lots of faffing about, probably easier to just rip it off and replace as the new stuff will be bigger than the old anyway.
These users thanked the author Rorschach for the post (total 2):
yartin (Thu Jul 25, 2024 1:52 pm) • Garden Gnome (Sat Jul 27, 2024 6:15 pm)
Rating: 14.29%
Has thanked: 735 times
Been thanked: 2339 times
Skirting Cover
never knew it existed :lol:
pretty much as above
assuming walls all over the place and you need to pull in via an area the old skirting is your fixings will need to be say 25mm into the wall
now it may go fantastic till the last fixing then it starts to pull the old skirting off the wall
yartin
Skirting Cover
Post by yartin »
big-all wrote: Thu Jul 25, 2024 2:07 pm never knew it existed :lol:
Same here , just came across them last night :lol:
Skirting Cover
another point
normal skirting is around 15-18mm possibly more so to cover would need to be perhaps 25mm and the architrave are likly to be perhaps 18-22mm so a problem there
yartin
Skirting Cover
Post by yartin »
It's not really worth it, easy to take skirting off the wall, I took off skirting few months ago to lay wood flooring and put them back without mush hassle.
These users thanked the author yartin for the post:
Garden Gnome (Sat Jul 27, 2024 6:16 pm)
Return to “General DIY forum”
