Mask
- Has thanked: 181 times
- Been thanked: 2 times
Mask
From personal experience, have any of you come across a really great mask that is effective against cement dust, sawdust, loft insulation, etc, etc, BUT, is also easy to quickly put on and is 100% effective against the things just mentioned?
- Has thanked: 807 times
- Been thanked: 3496 times
Mask
The best types are air fed systems but these can work out expensive. Here is a knock off version on Ali Baba https://www.******.com/item/1005003 ... y&src=bing& to give you an idea Our site is blocking the ali express .com as it is a bit spammy. Fill in the gaps with no spaces
