Winter treatment of fencing
Locked
leckyone
Has thanked: 7 times
Post by leckyone »
My feathered edge fencing needs retreating for the winter.
Previously I've used solvent based 'No Nonsense' Decking oil approx 2 years ago.
Can I use a water based type of treatment, but do not want to use the type that leaves a skin that peels off with time.
Any suggestions please :dunno:
Has thanked: 807 times
Been thanked: 3498 times
Water-based is normally a waxy finish that sits on the surface rather than penetrate the wood. The fact that you have used oil before it would be best to continue with a solvent-based finish. I used Barrettine which is a bit pricey but very good see https://www.toolstation.com/search?q=ba ... +preserver
dynamod
Elephant Man
Has thanked: 592 times
Been thanked: 1444 times
Post by dynamod »
:withstupid:
Oil and water are seldom a successful combo. The oil based fence products/oils are more deeply penetrating, though in direct sunlight, some can be photosensitive if they contact skin. Gloves and long sleeves are a good idea with some of these paints.
I've heard of old engine oil being 'recycled' as fence paint, but I'm pretty sure it's not the most environmentally friendly way to work.
Nihil expectore in omnibus
The engine oil thing was a mix of creosote and engine oil, not that common in use in my experience back in the 60s and 70s. Of course, it polluted the ground with runoff and killed plants so it gradually faded especially after it became known as a carcinogenic mix as awareness of this thing grew.
If you want a coloured fence then the water-based finished after more of a range, the oil tends to be shades of brown. The purpose is to preserve the fence, use solvent based.
Has thanked: 734 times
Been thanked: 2335 times
its worth mentioning iff you do nothing you fence will last as long or nearly as long [maybe 0-20% less but no actual tests done] as a treated fence
so no urgency to your efforts to make it look nice :lol:
Yes, that is true BA, I have never treated fence panels and most went 20 years before the replacement of some was needed.
dynamod
Elephant Man
Post by dynamod »
big-all wrote: Tue Aug 27, 2024 9:42 am its worth mentioning iff you do nothing you fence will last as long or nearly as long [maybe 0-20% less but no actual tests done] as a treated fence
I heard a few of the older guys saying that wooden fence work was largely cosmetic and little more than a way for councils to spend their budgets. I wonder if this was dipped/treated wood or properly bare timber?
Locked
